UL Rear Console Fuse
Reviving this thread - I'm experiencing avery similar issue with the rear seat control switch.
HVAC and Radio controls do not illuminate, nor does the LCD screen for radio controls. HVAC **** controls are intermittent and "stick" (either the green LED light stays on or off when you press the button to turn it on/off).
Power reclining seats, head rests, radio controls, sunshade, fridge, etc all work as expected.
Sometimes the radio screen will work, but will randomly turn off or will turn off if I press the HVAC control ****.
I've checked and cleaned all connections in the console as well as the rear fuse box. Also checked MPX-B1 fuse under the passenger kick panel. No dice.
Did you find any fix for this issue if you don't mind telling thanks in advance.
LS430inDE.
Apr 15, 2017 08:33 PM
