I'm baaaaaack! And going to replace front rotors
Old 07-26-14, 10:22 AM
Bocatrip
Bocatrip's Avatar
Originally Posted by warminwisc
The centrics I found to be excellent on my last LS not a wobble. These where the ones with the rust coating not the bottom tier one. I think there is a better and best. CAreful shipping will kill ya.
The Centrics from Rock Auto are for daily use and are part number 12044122. With shipping they come to $144.12
Old 07-28-14, 12:17 AM
SteveM
SteveM's Avatar
https://www.clublexus.com/forums/ls4...-photos-7.html
I did mine yesterday and added some comments to the DIY thread. Any other questions I can help with, PM me. Good luck and wow what a new braking feeling
Old 07-28-14, 02:44 PM
LS430inDE.
LS430inDE.'s Avatar
No kidding!? I'm jealous! I won't have time for at least 2 weeks before I can comfortably do my rotors. I will definitely checkout the thread that you provided, but if I can pick your brain a lil---did you remove the pads? Did you NEED to remove the pads if you did remove them? About how much time did it take for you to do one side, after you got the car off the ground?
Old 07-28-14, 04:28 PM
lsdude
lsdude's Avatar
And do you still have to pump the brakes after installing the new pads/rotors?
Old 07-28-14, 08:55 PM
740ilsamue
740ilsamue's Avatar
Its best to replace them. I had a similar issue with my Infinity q45, and ended up rear-ending someone. Better to afford the cost of replacing then the cost of an accident. My Infinity gave me warning that my recent brake job might not have been done correctly, cause a few times it didn't grab as usual, and the warning light came on a few times. I thought it had to be an error with the warning light, but during heavy stop and go traffic, my sudden need to stop was interrupted by the abs.
e-man
02-21-07 09:29 PM
HotBoy
Performance & Maintenance
03-23-04 12:06 PM
Vegassc400
SC- 1st Gen (1992-2000)
24
08-11-03 12:38 AM
One HoT
Maintenance
12
12-29-02 11:51 PM
GeneK25
07-17-01 10:40 AM
Quick Reply: I'm baaaaaack! And going to replace front rotors
