Power steering pump whine
#46
When I drive my 04 (110k), there's some kind of very high pitched "whine" at freeway speeds (70-80) when tach is roughly 1,700 - 2,500. Not super loud but just enough to be really irritating. Kind of like a dentist's drill. Michelin tires are in excellent condition. Other the "dentist drill whine", the car looks and drives well. I tried coasting in neutral. No noise. It's not the stereo. No wind noise. There's a slight vibration at idle which is probably engine/trans mounts.
So to compare, I drove an 06 in perfect condition. Elderly woman owner, full service. Didn't make any noise at idle or any speed. No whine. Just like the 01 I sold.
Can hear the PS pump on mine at idle (loud when cold, can hear slightly when the car's warmed up). Could this be the source? I've heard about 04's having a "mystery whine". Mine didn't need a trans replacement. I did a couple of D/F's. Dealer did the second. Shifts are super smooth. Other than the noise, the car is a perfect low mileage car. Any suggests on ways to solve the whine? Am ready to sell my 04 and buy the 06 (10.5). Perfect one owner but not a Sport.
Side note: the 06 isn't a Sport (mine is) but doesn't feel much different. Not much body roll. There is some road feedback. My 01 was soft. Noticeable body roll and totally insulated from the road.
The fact that you mentioned no noise while coasting in neutral makes me think it's in your driveline/rear diff. I'm very ocd and I have a similar BARELY noticable high pitched whine, but it's only if she's kept at a steady speed, either using the gas or cruise. (I ask other passengers and they don't hear it!) The slightest deceleration or acceleration and the barely noticeable high pitched wine goes away. I'm going to be changing the rear diff oil soon. Have you ever changed the rear diff oil?
#47
Maybe its the pinion bearing?
#48
#49
Took a while to find a good pic...
The arrow points to the one bolt holding it on. Just pull it straight out which is towards 3 o'clock in this photo. The electrical connector shown just above the cylinder will obviously have to be detached. Once you pull it out be very careful as there are 3 o rings on the valve that are rather delicate.
Catalina45 (03-01-18)
#50
What owners of our cars that have not had them for a long time (10 years plus is an example) is that many of these symptoms do not necessarily connote to imminent failure. Not every faulty part in the LS430 needs to be replaced because of noise, rattle, etc......Our parts are quite robust and can last for the life of the car, regardless of symptomatic issues.
#51
Drove 100 mi today. Dentist drill whine at 70-80. Parked, get the same whine at starting at 1,700 and clearly coming from the engine. The higher the rev's, the louder it gets. It was quite noticeable after driving 50 miles. One day this week, it vanished. Nothing the whole drive (60 round trip) then back the next day. Stethescope test results: AC compressor quiet, idler pulley quiet, PS pump sounds like sheet metal grinder. Electric fans weren't running. Car has 111k. 90k done by dealer. I did completely flush and refill PS fluid. Totally quiet but noise is back. Anything else I should check before replacing the PS pump?
#52
Did you put the stethoscope on the tensioner pulley or the fan bracket ? I think I would take the serp belt off to isolate all the components. If you still hear it then it's a water pump (bearing) issue or something else timing belt related.
Although your comment re the sheet metal grinder may be very telling...
#54
Could it be coming from your drivetrain? Rear diff? What's the sound if you're using cruise control at 70-80? What happens when you take cruise off and coast IN gear? If it in fact was the PS pump, wouldn't the noise still be present? Regardless if the car's in or out of gear, the PS pump is still going to be churning!
#55
Here's the sound. Sound like the PS or something else? 90k service by dealer (new timing belt, etc). Car was quiet when I bought it (103 then, 111 now). Noise started. Did PS drain/refill. Quiet but it's getting loud again. I guess the other possible is the alternator bearing. Haven't had time to remove serpentine. Feedback appreciated!
#56
Sounds like you have to rev the motor to produce the noise. When you start the car in the morning, first start of the day, you can rock the steering wheel back and forth from 3 o'clock to 9 o'clock. If this produces the same noise it's your PS pump.
#57
Thanks for the feedback. I get pretty much the same noise in the am w/o even turning the steering wheel. Per stethoscope, PS sounds like a sheet metal grinder at idle and gets worse when rev'd. Checked my neighbors Tundra to compare. Very little noise. I've never had a car w/ a whine that I could hear at 70-80! Just making sure it's not the alternator bearing or something else.
tallcaguy (03-29-18)
#60
alternator replace
Turning the wheel does amplify it. I'm sure the pump is a factor. If I just had the noise at idle and cold, I wouldn't replace. It's the whine I can hear at 70-80 that's the problem. A PS pump can make that much noise? It's the same "screeching" sound you can hear in the video. I put the stethoscope on the AC compressor (quiet), idler pulley (quiet) and PS (dental drill).
