Water pump broken?
Old Jun 9, 2011 | 01:16 PM
dejavu157's Avatar
dejavu157
Default Water pump broken?
Hello i recently purchased this water pump. Does this hairline crack matter and i should return it, or does this tiny crack not mater. Thanks everyone in advance!
Old Jun 9, 2011 | 01:28 PM
94LSon20's Avatar
94LSon20
That does not look like it should be there. IMO I would return it
Old Jun 9, 2011 | 02:09 PM
AznRacer's Avatar
AznRacer
Just save yourself the headache just in case if it does break
Old Jun 9, 2011 | 02:32 PM
dejavu157's Avatar
dejavu157
ok. thank you. thats true. i got another 500 miles before 90k anyways, worth the wait i guess.
Old Jun 9, 2011 | 03:35 PM
Bon's Avatar
Bon
This is how mine looks.
Old Jun 9, 2011 | 04:18 PM
imherenow's Avatar
imherenow
one question since i got timing belt replaced but not water pump..whats the function of the water pump and what would make it deteriorate fast..like turning on a/c too much etc??
Old Jun 9, 2011 | 04:29 PM
caddyowner's Avatar
caddyowner
I read somewhere that a new timing belt puts additional (or simply different) stress on the water pump which could cause it to start failing.
The A/C compressor is driven off the serpentine belt, so I don't think that would have any effect on the water pump.
Old Jun 9, 2011 | 06:26 PM
jayclapp's Avatar
jayclapp
The water pump runs continuously when the engine runs. Since it is belt driven by the engine the water pump speed varies directly as the engine rpm changes. Consequently, it is subjected to many possible natural resonate frequency modes which enhance the stress and vibration of the blades which can cause early failure of the blades. A proper design would take this into consideration and minimize the possibility of such failure. I would suspect that the most common cause of water pump failure would be bearing or gasket failure. Regardless, the water pump should have a reasonable life if properly designed and manufactured properly. I would beware of non-OEM parts personally.
I would not accept a new part with a hair line crack. Not only would I return it, I would not purchase another pump from that supplier. Run away.
Old Jun 9, 2011 | 10:28 PM
Jabberwock's Avatar
Jabberwock
Agree - when in doubt return the pump. Water Pump failure in an LS430 can be catastrophic especially if it breaks and jams the timing belt you can kiss the engine hasta la vista.
Old Jun 11, 2011 | 07:14 AM
imherenow's Avatar
imherenow
Good to know thanks..but the lexus manager said no need to change the water pump when I was there for a timing belt change..its on my ES300 tho..so ya he said he would change only if it was leaking and from his experience he has never changed a water pump as a part of timing belt maintraince..however he did inspect the water pump and said was fine..hmmmm
Old Jun 11, 2011 | 04:17 PM
randal's Avatar
randal
Function of the water pump? It circulates coolant throughout the engine to keep the temperature at a proper level. Without the pump, an engine would quickly overheat.
What makes a water pump deteriorate the fastest is neglecting to change the coolant at the scheduled maintenance period. Usually, a good point is 3 years or 30k miles. The pump has a seal to prevent coolant from seeping into the bearing. Old coolant starts to break down the seal and can cause premature failure of the seal and, after some time, the bearing. There is a so-called "weep hole" in the pump to allow coolant, which is leaking past the seal, to escape to the outside of the engine. A small puddle of coolant on the floor can alert a perspicacious owner to an impending disaster.
Dealers do not recommend changing the pump along with the timing belt but they should. The labor is fairly intense getting to the timing belt and water pump. Therefore the majority of the cost of either is the labor. While having the timing belt changed, it is a rather trivial matter to also change the pump. The dealer would probably like to have you return in another 30k miles for a new pump and to charge the labor all over again. Always change the pump with the new belt. Cheap insurance!
If that is a hairline crack on the new pump, then yes, return it. If just a superficial scratch then its ok. If in doubt, just return it.
Old Jun 11, 2011 | 06:57 PM
imherenow's Avatar
imherenow
aahhh crap now i feeel stupid ..i told the lexus manager to change it based on what i read on this club lexus forums... but he was soo sure that it wasnt needed..no i will have to do it again down the road with same labour cost...arrrrr
MellonC00
Hybrid Technology
Jan 2, 2026 07:05 AM
GibbsLexus
Aug 9, 2017 07:18 AM
Harvey99
May 30, 2015 08:04 AM
Cezlex
Dec 24, 2011 10:15 AM
werewolf
Mar 8, 2010 06:31 PM
