Park roll.
Old May 25, 2011 | 05:01 PM
monkeybutt's Avatar
monkeybutt
Default Park roll.
My driveway has a slight incline and when I put the tranny in my '03 in Park and then let off the brake it rolls back enough to cause a lurch when the tranny finally stops it. Is this normal? Maybe it is a Lexus thing as my wife's RX330 does this, but to a lesser extent. I know all auto transmissions will have some roll/play but the lurch w/ the LS is much more than my Acuras have had.
I know easy remedy would be to step on the parking brake before easing up on the brakes. Just find it odd on a luxo vehicle.
Old May 25, 2011 | 05:14 PM
CarGuy89's Avatar
CarGuy89
It sounds normal, park an auto on any steep hill w/o the parking brake will cause the car the roll back and lurch to a stop. Put the parking brake on before letting off the brake pedal so that the brakes are holding the car, not the transmission. Putting the car into gear should feel much smoother if you engage the parking brake first.
Old May 26, 2011 | 06:13 AM
Marklouis's Avatar
Marklouis
a heavy Luxo vehicle at that. it is recommended the the parking brake is applied on any surface to keep the weight off the transmission park pin.
Old May 30, 2011 | 01:16 PM
toantran99's Avatar
toantran99
I always use the parking brakes regardless of where I park, save the transmission from going bad.
Old May 31, 2011 | 12:39 AM
VNN326's Avatar
VNN326
its normal
anniemac
Dec 18, 2023 02:21 PM
05Flagship
Aug 8, 2015 10:03 AM
cless
RX - 3rd Gen (2010-2015)
Dec 26, 2013 06:15 PM
nighthawk
Suspension and Brakes
Jul 31, 2011 04:13 PM
Turbinator
GX - 1st Gen (2003-2009)
May 10, 2010 10:22 AM
