waijai's LS430: Crystal White, Saddle, Wald, Weds
Old 01-30-12, 09:43 AM
  #61
waijai
waijai's Avatar
Originally Posted by sojah
my rear fenders have already been shaved paper thin and the tabs have been shaved down too.
so you think its not as simple as just heating and pulling on the fenders with one of those fender rollers??
It should be pretty straight forward, although I don't know what the limits are to pulling. I don't think mine require that much work, but we will see later today.
Old 01-30-12, 11:40 AM
  #62
sojah
sojah's Avatar
ohh, i thought you were getting yours pulled? so what sort of fender work are you getting if you don't mind my asking?
and by the way how did the overall sale go with that guy and the trafficstars (21's) that we had talked about that one time? was it all legit 100%.?
Old 01-30-12, 01:22 PM
  #63
ultm8mind
ultm8mind's Avatar
Good luck man, can't wait to see them on the car!!
Old 01-30-12, 01:59 PM
  #64
alredxiii
alredxiii's Avatar
Default ls430
Where are the pictures of the SADDLE INTERIOR????
Old 01-30-12, 07:55 PM
  #65
waijai
waijai's Avatar
After testing fitting, the fronts only need a slight pull. The rears however are going to need some work...at least a 20-25mm pull.
The sale back then went fine and I had no problems really. The only problem was not knowing the front wheels were low-disk, which made me have fitment issues after needing a spacer to fit the brakes.
Old 01-31-12, 05:15 AM
  #66
sojah
sojah's Avatar
^ ^ ^ this is what I was considering a 20-25mm rear fender pull. so therefore i'm really interested to see/hear how yours turns out
Old 01-31-12, 05:44 AM
  #67
waijai
waijai's Avatar
Yeah, if I were to dial in more negative camber I wouldn't have to pull as much, but I don't want the super camber look.
Old 01-31-12, 06:05 AM
  #68
sojah
sojah's Avatar
i drive too much for camber and camber kills, tires that is.
Old 01-31-12, 06:43 AM
  #69
waijai
waijai's Avatar
Here's a shot of the rears and how much work needs to be done. After a few minutes, the car did lower a bit more and camber in enough to cover the word "Max" on the tire.
Old 01-31-12, 08:44 AM
  #70
sojah
sojah's Avatar
nice pic but still a little hard to see how much from that angle. so its about 20-25 mm needed after it settles on the max on the tire?
well i guess that is what my future setup would look like consider that is exactly what i was planning, in my head at least. when are you getting the work done?
Old 01-31-12, 11:53 AM
  #71
VNN326
VNN326's Avatar
dang thats gonna be one pull. haha good luck can't wait till the finished product!
Old 02-01-12, 09:12 AM
  #72
Selah777
Selah777's Avatar
That roughly about what I had to pull. Good luck and have fun!
Old 02-01-12, 10:56 AM
  #73
waijai
waijai's Avatar
getting there...still need to work those dimples out
Old 02-01-12, 11:13 AM
  #74
GR6RR
GR6RR's Avatar
yea buddy! startin' to look real good.
Old 02-01-12, 03:06 PM
  #75
sojah
sojah's Avatar
hmmm... so its not a science to get the perfect 20mm pull i guess huh?
hey selah can you recommend a good shop in the DMV area and how much did you pay to have yours done?
Quick Reply: waijai's LS430: Crystal White, Saddle, Wald, Weds
