Lower Control Arm Bushing Repair
Old Nov 24, 2022 | 07:40 PM
  #301
icasak99's Avatar
icasak99
4th Gear
@Bexar Hey man, I made the exact same mistake and have stripped that hole as you did. What was the process you went through/any tips to get that fixed?
Old Nov 29, 2022 | 08:07 PM
  #302
StanVanDam's Avatar
StanVanDam
Same. I did my passenger side no problem. Same order of operations on the driver side, which followed the service manual on which bolts to do and when to load and unload the suspension. Cross-threaded the closer of the 2 subframe bolts on my driver side. It's in there tight enough that I don't think it will go anywhere, but I will eventually take it to a shop or dealership to see if they can get it on a lift and line it up right.
I used the RC-F/GS-F brackets+bushings, 45516-50030 and 45516-50040. I kept the original metal protector hats on the front of the bushings per factory install. Someone on a YouTube video said they threw those out, but I think these metal shields protect the bushings from flying rocks and other road debris coming from the front.
Also noticed that my LCA bushings were oriented incorrectly from the factory, the little nub was on the top instead of on the bottom. Either they pressed in the bushings wrong, or used left-side brackets on the right and vice-versa. It's the only thing I recall that was installed incorrectly from the factory. Both left and right side brackets will fit on either left or right, so you have to use the one where the nub is on the bottom.
Old Nov 30, 2022 | 12:08 PM
  #303
icasak99's Avatar
icasak99
4th Gear
@StanVanDam Yep sounds like you might be okay, the one I've cross-threaded was the big M16 bolt that goes through the bushing bracket itself so i'm guessing it's pretty critical.
Currently trying to get a helicoil up there but it's recessed by the front subframe crossmember which makes it very difficult to drill out... Out of ideas right now!
Old Nov 30, 2022 | 03:07 PM
  #304
nvwls's Avatar
nvwls
@icasak99 That bolt goes into the LCA, you should probably just replace it at this point. I cross-threaded the inner bolt and had to tap it. Make sure to remove that original metal protector/bracket in front of the bushings otherwise they won't align properly and the ride will be too harsh. I drove around for a couple months with those on and the ride was tight but almost too tight and I got too much feedback. Once I removed it the right was sporty but not as harsh and the two other bolt holes lined up perfectly. (Also used GSF/RCF bushings)
Old Nov 30, 2022 | 03:54 PM
  #305
icasak99's Avatar
icasak99
4th Gear
@nvwls I've stripped the threads up there so I think we might be talking about different bolts. The other side went in perfectly, I started by hand both times but unsure why this side is so difficult, maybe I skewed it when I went to remove the bolt.
Old Dec 2, 2022 | 05:55 PM
  #306
nvwls's Avatar
nvwls
Sorry misunderstood what you said, I thought you meant the center bolt. I stripped the inner one, looks like you stripped the outer one, basically the same thing. Short of replacing the subframe your best bet is still to tap the threads. I didn't have any difficulty reaching the inner bolt threads, are the outer ones more recessed?
Old Dec 11, 2022 | 07:09 PM
  #307
icasak99's Avatar
icasak99
4th Gear
Yeah the thread is completely recessed and that brace is in the way of easy access. I might just try tap it again and see what happens....
Old May 9, 2023 | 05:30 AM
  #308
Commuter's Avatar
Commuter
Just wanted to add my experience in replacing original lower control arm bushings on my 2005 ML LS 430 with 140k miles.
- I got OEM bushings from Lexus of Akron online rather than the IS/GS new ones because I had a free way to remove the original bushings. They look a little old, but are in much better shape than the originals.
- removal of the bushings per instructions was easy
- put bushing in freezer for a few hours and a friend with a 3" arbor press popped them right out and inserted the new ones (although the passenger side nub is about 15 deg off center; I wasn't going to complain since I paid $0.00 for his help)
- reinstallation went well and I was very careful to not cross thread the 17mm small bolt on the inside of the car. I had to use a lever to slightly pull the control arm to the inside to get it aligned.
- I tightened the horizontal nut at the end of the control arm first, then the two side bolts, then did it again to make sure everything was snug all by hand to ensure nothing got catawampus.
- used my trusty Hazard Fraught torque wrench set to 104 ft-lbs for the two 22mm bolts and 44 for the 17mm bolt and went around all bolts 2x
- reattached the splash shield and bob's your uncle.
I'll probably check torque if I remember after a week or so of driving.
Did I notice any improvements? Yes - I'm sure a decent amount of this is psychosomatic, but the soft 'clunk' going over driveway ramp and potholes is gone; turn in feels better; slightly less steering corrections needed at speed on highway.
I haven't yet noticed a need for an alignment.
Old Jan 19, 2024 | 06:30 PM
  #309
ocethunder's Avatar
ocethunder
9th Gear
did you ever happen to get yours fixed? If so what process did you do? Im trying to tap the few threads i messed up but if you have a safer solution id love to hear it.
Old Feb 16, 2024 | 08:05 PM
  #310
kn171's Avatar
kn171
Sorry if I missed this but did anyone who replaced it with the IS aluminum bushing keep the little "splash plate" piece that went behind the original bushing? I removed mine as it didn't seem to have enough clearance to fit and even though the steering has tightened up significantly, my car seems to have developed a new clunking sound. Appreciate the help!
Old Feb 17, 2024 | 08:32 AM
  #311
slightreturn's Avatar
slightreturn
Originally Posted by otcviper
Greeting all- Just talked with my friendly Lexus dealer who informed me that there is no such thing as a replacement LCA Bushing for an '02 LS430, you have to buy the whole dang control arm at the bargain basement price of $224 ea. Yes, you don't have to worry about pressing (or burning) out the old bushings which saves time, but $224? Jeez.
He also told me that NOBODY makes an aftermarket part for it . Hmm. I know that Daizen does not (really wish they did), but a simple search proves that it's available. Wondering if anybody has a recommendation on who to buy these from and if there is a superior brand out there.
Also, wondering if anybody has DIY'ed this. I have a shop manual that outlines the whole thing, just wondering if there are any things I need to keep in mind.
I don't post much here, but I do read everybody elses posts a lot and appreciate all of the great information I've consumed over the past 6 months!
Thanks!
Hmmm. Assuming the facelift cars are the same as pre-facelift, it should be no problem to get just the bushings themselves. I bought a pair of OE Lexus LCABs for my '05 (I could be wrong but I think they were about $90 each), brought them to my indie mechanic, and they had no trouble installing them. Really cleans up the handling. Highly recommended. I don't trust aftermarket parts for these cars ... the OE ones are always much higher quality.
Old Feb 18, 2024 | 09:09 AM
  #312
FIGS's Avatar
FIGS
The Maker
Here you go.
https://shopfigs.com/v5/index.php?ro...h=Ls430%20%231
__________________
Redefining Lexus Aftermarket Parts Since 2001
-- We are your Lexus suspension experts--
BCR - KW - PENSKE - OHLINS - HKS - GREDDY - STANCEPARTS
Links - Arms - SuperPro Poly Bushings - Solid Bearing Conversions - Motor Mounts
RB BBK's and 2P Rotors, G-Loc pads, Radium Fuel Systems
Custom Fabrication Design and Machining - Industrial 3D Printing - Laser Cutting
2018 USTCC Sportsman Class Champions - 2018 NASA ST5 National Champions
Old Feb 18, 2024 | 07:18 PM
  #313
BBE4300's Avatar
BBE4300
I still have the plate on, and I changed to GSF OEM Bushings
Old Feb 20, 2024 | 08:08 AM
  #314
JOEYD2008's Avatar
JOEYD2008
Hi There, did you use Part No. 48075-24010 & 48076-24010?
Old Feb 20, 2024 | 08:11 AM
  #315
JOEYD2008's Avatar
JOEYD2008
