2004 LS 430 Nav
Old Oct 29, 2009 | 07:22 AM
AudioBuff's Avatar
AudioBuff
Default 2004 LS 430 Nav
I just picked up my first LS 430 last night (2004 Modern Luxury - silver/black).
I have a question...is there a way to adjust the NAV's screen for nighttime viewing? It's really too bright and I couldn't find anything in the options menu.
By the way, this one has the back-up camera (I guess it was manufactured closer to 2005).
Thanks!
Old Oct 29, 2009 | 07:36 AM
toantran99's Avatar
toantran99
Congrats on your new ride but there should be a settings in there. Check the manual. I don't have the manual with me at the moment.
Mine change to nightime mode when my lights cut on. It's set to auto.
Old Oct 29, 2009 | 08:29 AM
sojah's Avatar
sojah
yes there is a setting, i turned mines down a lot for the same reason... i wasn't used to this big glowing screen in my car at night time. it is pretty damn bright.
Old Oct 29, 2009 | 10:35 AM
mikevanle's Avatar
mikevanle
If you adjust the dimmer "****" on the left of the steering wheel, it'll do it. If you turn the **** you'll hear or feel it "click" when it's set to full brightness. Just turn it a little bit left so it's not all the way set to brightest, and you'll notice your nav screen go into night mode when it's dark outside.
Old Oct 29, 2009 | 10:46 AM
AudioBuff's Avatar
AudioBuff
Thanks! I'll give that a try tonight!
Old Oct 29, 2009 | 08:16 PM
BMW7_LS430's Avatar
BMW7_LS430
Thanks!
Congratulations!
Seems like you picked the best year and interior/exterior color.
Old Oct 29, 2009 | 08:18 PM
LS430inDE.'s Avatar
LS430inDE.
Originally Posted by BMW7_LS430
Congratulations!
Congrats on the pickup! ^^^^And I agree with the 7-series beemer ^^^^^^
Old Oct 30, 2009 | 05:55 AM
AudioBuff's Avatar
AudioBuff
Last night, I turned the **** to dim the NAV. It only dimmed the dashboard lights...the NAV was unaffected.
Well, back to square one. Any other suggestions?
Old Oct 30, 2009 | 08:00 AM
ayonnebay's Avatar
ayonnebay
It's in the Nav manual, but you should be able to figure out how to switch it to Automatic. Probably under the "Display" settings. I know it can be done. The dash brightness doesn't do it - it's done using the Nav screen.
Walt
Old Oct 30, 2009 | 06:34 PM
Tee's Avatar
Tee
The display button gives you Contrast and Brightness adjustments for the Nav screen.
Old Oct 30, 2009 | 08:13 PM
ayonnebay's Avatar
ayonnebay
Yes, but the choice to place the display in "DAY" mode (which is the mode the OP's display is in) is made by pressing OPTION, and then DISPLAY with the light switch in the OFF position. I don't know why that is, but ......
Anyway - Turn the headlight switch off, then press Option, then Display. DAY mode is then toggled (I believe) by the DAY button at the top of the screen.
Walt
Old Nov 1, 2009 | 03:35 PM
JDMUSCLE's Avatar
JDMUSCLE
ONCE you take the dimmer of the brightess settings, you will now have a new button appear on the display settings for the NAV screen .... all you have to do at this point is select the auto and you will have it dim automatically when the lights are turned on....
pcnewman
Nov 17, 2017 10:52 AM
CeeB
LX - 3rd Gen (2008-2021)
Oct 1, 2015 07:14 AM
isthrizzy
Apr 21, 2009 12:19 PM
gcantu
Feb 16, 2009 07:34 AM
PsychDoc
Jun 9, 2006 01:39 PM
