problem with accessory outlet
Old Dec 14, 2008 | 02:21 PM
LS430Rus's Avatar
LS430Rus
Default problem with accessory outlet
i got an 01 ls430 ul and the outlet for the cig ligther stopped working by the shifter. the one in the back and inside the center council works. the light in the ash tray is on. this is really weird any solutions for this. thanks
Old Dec 14, 2008 | 04:13 PM
Tee's Avatar
Tee
THe fuse is blown, it is a common problem with the LS. Just replace it and you will be good to go!
Old Dec 14, 2008 | 07:03 PM
jman-LS430's Avatar
jman-LS430
Yes, this happened to me recently. Also, the way the fuse layout is marked is backwards, I think. So if the fuse you pull looks good, try the other one since it seems like they are labeled backwards (could just be me).
Old Dec 15, 2008 | 10:01 AM
GS3Tek's Avatar
GS3Tek
Yep, mine blew also.
I can't remember but I think it's the one by the front passenger side.
Old Dec 15, 2008 | 10:26 AM
Tee's Avatar
Tee
You are correct, the fuse for the lighter is on the passager side.
Old Dec 15, 2008 | 09:29 PM
LS430Rus's Avatar
LS430Rus
yea ill have to check that out and let you guys know, that should be in the fuse box under the hood right.
thanks
Old Dec 16, 2008 | 05:00 AM
Tee's Avatar
Tee
thanks
No. The fuse for the lighter is on the passager side inside the car, there is a little door on the side with a **** sticking out (where your right leg would be).
SoCal Cyco
Dec 1, 2022 04:29 PM
edvc520
Dec 1, 2022 09:46 AM
ksan
Jul 30, 2014 05:28 PM
mikevanle
Dec 6, 2010 06:32 AM
mcnelson
Aug 5, 2002 05:13 AM
