Navigation trim paint?
Old Nov 25, 2008 | 07:10 PM
TPSTulane's Avatar
TPSTulane
Default Navigation trim paint?
Just picked up a 2002 LS430, The only problem area I have is that the previous owner must have worn a watch because he wore the paint right off the trim. Anyone else had this problem? Any suggestions on where to get some trim paint? Thanks.
Old Nov 25, 2008 | 08:45 PM
airtime's Avatar
airtime
CL Folding 1,000,000
I bet the previous owner had something clip in the right air vent, and whatever it was, it keeps rubbing
This topic has been discussed before. Some opted to get it professionally painted while others decided to take the trim off and do it themselves.
Any way, welcome to CL.
Old Nov 25, 2008 | 09:48 PM
GRAND_LS 4's Avatar
GRAND_LS 4
3UZ-FEEEE
I've seen issues like the before but i'm guessing its due to massive rings/long finger nails some people wear.
I would just look for the part on ebay first, that part is small bezel that shouldn't be hard to source.
Old Nov 26, 2008 | 03:28 PM
AlexusAnja's Avatar
AlexusAnja
I've read there is "touchup paint" for that part which matches the color, but with that much damage, that would require a lot of paint. I doubt it was a watch, probably rings on finger and pressing the damn "I agree" button every single time scratching the bottom right.
Removing that bezel requires the removal of the bottom piece first, then the CD door, then the radio piece, then the NAV piece... just a long sequence of pieces.
Old Nov 28, 2008 | 12:20 AM
usermel's Avatar
usermel
Smile You can by an aftermarket woodkit!
An aftermarket woodkit can cover up most of the outside marks and make any other marks look less obvious if not at all obvious! Woodkits do cost a few bucks but, the touch up paint may not match well with that many scratches! I dont know the cost to buy and install a new part either but, the woodkit is a thought. I have once(birds eye maple woodkit) and they do add to the interior look as well.
All the best when you decide what direction you want to go in. The other option is leaving it as is. May not like that idea but, I think a few marks hear and there add character to a car, it looks driven and not perfect. I have a few marks on the interior myself(2001 LS 430)!
Old Nov 28, 2008 | 12:27 AM
usermel's Avatar
usermel
Smile WoodDash.com is were some woodkits are sold!
Hey, my woodkit is Golden Birdseye, not birdseye maple. Also the kits run about $220 and up at wooddash.com and may find a cheaper price at other companies but, thats wooddash.com's price! All the best!
L.G.N.M
Old Nov 29, 2008 | 09:36 AM
spender's Avatar
spender
I had exactly this same problem, and long story short, because it is arguably the most visible/noticeable spot in the whole car, touch-up paint won't do it - it's still too noticeable, and you'll never get a perfect match. Might be okay for a Ford, but not a Lexus. In my case, I ordered a new nav surround assembly (it comes with the vents), was around $200 from Sewell, and then took my car apart to replace it (wasn't that hard - I have a thread here with pictures if anyone wants to find it).
Old Dec 24, 2008 | 01:39 PM
patmall's Avatar
patmall
Hi;I would like to have the thread about the Surround Assembly Thanks and Happy Holidays. Pat.
Old Jan 3, 2009 | 05:12 PM
spender's Avatar
spender
https://www.clublexus.com/forums/3127937-post27.html
Old Apr 23, 2012 | 08:01 PM
10scjoejaw's Avatar
10scjoejaw
Had the same situation with the trim around my '04 LS430 Navi-screen when purchased from ATL dealer as a CPO... It was on my short punch list prior to purchase. Appears that previous owner would rest the fingers ( middle,ring and pinkie) on the base surface while using the touch screen. This is a normal gesture that allows the right hand to remain steady while touching the screen however the oversight of the "high traffic activity" to the interior cabin engineers responsible for fit and finish resulted in worn paint and a unsightly trim piece. The piece was restored by the the dealer via spraying the identical metallic paint and was no big deal. I say that because it was done fast and appeared to be somewhat of a routine procedure. That said, I hope it helps and it would behoove future design to consider this poor or lack of planning to utilize a glossy piano black or conversely a friction surface that is impervious to daily repeated contact... Maybe even a glass-type base? I need input touching up the stock alloy wheels ...little nicks and such. If anyone's had success with duplo or any brand of touch up paint for the 2004 LS430 wheels (no nail polish suggestions pullleeze...)
Jwconeil
IS F (2008-2014)
Oct 7, 2018 02:40 AM
zhifan1
Jun 25, 2017 10:13 PM
ISzBest
Automotive Care & Detailing
Jun 18, 2014 12:52 PM
olsen_karl
Dec 5, 2009 06:14 AM
Eggman
Jun 5, 2007 12:02 AM
