AC front Vents oscillating problem
It might be something to do with a sensor..The way I understood the Oscillating Fan..it senses hotspots in the car and also if there is a passenger or not...It will blow the AC on the hotspot until the temperature is even between the driver's and passenger's section.
I notice it blows only the driver's side (for a little bit) when I have no passenger..then it will eventually even the distribution of air out.
Mike
Mike
have watched mine and the vents start moving immediately after hitting the nav screen button,, "appears" they continue to move at the same speed and width of sweep,, never have seen it deviate,,??????
guess something back in the drive unit may be out of whack or broke if it is not working,,
daughter had this feature on her Nissan many years past and she used it all the time and never had a probloem with it,, I always thought it would shoot craps as a first item in need of repair,, never broke,,
oscillating switch is turned on under climate screen option. I remember in the 01-02's LS430 as soon as you switch the oscillating button on or press auto , it starts oscillating right away.
Tried leaving the air on auto for more than 10 mins and vents doesn't oscillate so i am guessing there is definitely something wrong with them. Should i bring it to the dealer's attention, since i have 30 days. But i am afraid they are going mess things up since they are not lexus dealer.
They wont know how to fix it. Bring it to the dealer, your car is under warranty unless you have more than 50k miles. Try deactivating them and then activating them it may work. Good luck.
I thought I had the same problem until I looked in the manual. To re-iterate another post, the oscillation depends on the temperature inside the car. Even how far the vents swing are variable. I just made sure the option was activated, then relaxed as it went to work.
Incidentally, there have been about 5 things I thought were broken on my car. First was: "Hey, why won't the side mirrors tilt down anymore?"
I hope everything works out for you, though!
Have noticed lately that only the passenger side oscillating vent works. The drivers side vent never moves. I have tried various temp. settings and still the drivers side vent does not move. Could it be a faulty sensor or is there a motor for the drivers side vent that has failed. Any ideas or thoughts would be appreciated.
