View Poll Results: Does it work?? Did it ever break??Repaired??
Yes it Broke and had it reapired....
73
27.55%
NO. The Suspension works like a charm...
176
66.42%
YES, my AIR CONTROLLER broke it...
16
6.04%
Voters: 265. You may not vote on this poll
LS430 UL with Air Suspension...Post your Issues Here
Old 08-16-10, 08:02 PM
  #91
wildace
wildace's Avatar
my UL is having issues with the rear shocks. the compressor is pumping air but the rear just wont come up. i have a datasystems and it shows the rear shocks blinking but nothing
Old 09-14-10, 01:21 AM
  #92
convoy
convoy's Avatar
i have a wacky problem with my 01 UL with air ride controller. it has a mind of its own. i'd be driving on the freeway, then all of a sudden... the car would just lower itself automatically.... like to the ground. then at other times, the car would raise while i'm driving to work... to full height. now it does this thing where the front stays at its current height, but the rear raises to full height... making the car slanted. i don't know what the hell is going on. maybe it has something to do with the datasystems controller. if this keeps going on i might just switch to a coilover setup.
Old 10-04-10, 11:05 PM
  #93
wopdud
wopdud's Avatar
Default Mine is 2002 ls ul with 960034k air sus
lowered by sensors, but use high height button to bring to normal height and it rides great,a little stiffer in lowered position.still happy with it. Got my fingers crossed after reading all these coments.
Old 10-05-10, 01:28 PM
  #94
94LSon20
94LSon20's Avatar
01 UL with 115k, no problems yet. Just modified my sensors yesterday. Fingers crossed
Old 10-18-10, 08:27 PM
  #95
rizo1
rizo1's Avatar
If one were to convert there air suspension to coil..what would be the best way to go about it? any recommendation for the best and smoothest coils to best replicate the air ride? Thanks!
Old 10-19-10, 04:59 AM
  #96
94LSon20
94LSon20's Avatar
Rizo check FAQ and there is a thread on the first or 2nd page of the LS430 forum answering your question, browse a little & you'll find it
Old 10-30-10, 04:40 PM
  #97
aypues
aypues's Avatar
I had my right rear shock absorber replaced. I think this is the air suspension, right? (ihave a UL). It was like $1250 parts and labor to replace, but it was covered under my CPO warranty. The car drives SO much better now. SO SMOOTH over normal bumps I would avoid, and no left-right instability when going over severe bumps. LOVE my air suspension! The sport setting is also a LOT more tight and responsive.
Old 10-30-10, 07:41 PM
  #98
bernard 96
bernard 96's Avatar
just sold my 96 ls400 with air suspension with 160k, only replaced a sensor but ride was not smooth at that mileage. Just got a 2002 ls430 base model with 59k with leaky right rear shock with rattle going slowly over bumps. No local lexus dealer; midas wanted 900 to replace both rear shocks. Got oem shock myself from a lexus dealer for 120, had it installed for 60. Other three shocks are fine. Always worried about the 96 air suspension shock replacement, but they are still going at 160k. But it sure was easier to replace the base model non air shock on the 430.
Old 10-31-10, 10:17 AM
  #99
aypues
aypues's Avatar
aren't you supposed to replace shocks in pairs if it's non-air suspension? or is that struts? I don't know the difference. I know I had to replace 2 when one went out on my SC400.
Old 02-25-11, 06:44 AM
  #100
waijai
waijai's Avatar
Datasystem has been going wacky lately over the past two weeks. It started all after we had a big freeze here in Texas. Yesterday I unplugged the Datasystem while driving and the AFS light started blinking. Shut off the car, turned it back on, and the AFS light was still blinking. Shut off the car again and then plugged the Datasystem back in and car seems to be working normal again.
Ready to take the car to the dealership though.
Old 07-19-11, 05:02 AM
  #101
Sentinel
Sentinel's Avatar
My right rear went was was replaced. I have the feeling a front shock is gone now I will have to check today. Yup Front driver shock is gone Leaking from top
Old 07-20-11, 05:54 AM
  #102
weizs13
weizs13's Avatar
im just really curious about getting the datasystems controller i have 102k already no problems yet with my air suspension. i have already done the manual adjustment. one problem with that I put my driver side all the way down and it still wont match the passenger side maybe a sensor problem
Old 07-31-11, 04:01 PM
  #103
weizs13
weizs13's Avatar
04 UL just hit 102k driver front strut is starting to leak any words of advice megan coils or oem air strut
Old 12-02-11, 11:13 AM
  #104
drdarell
drdarell's Avatar
My '02 has 147K on it and the left rear is leaking. This car has an incredibly smooth ride and I love the air suspension, until it comes time to replace it. I never figured this car would ever need struts replaced. I figured that this was a Japanese built car and had exceptional quality. Well they are getting sloppy... I had a '90 accord that was built in Japan and this was the best built car I've ever had. (I thought my LS430 was even better but it's not). The Honda had 265K miles on it when I gave it to a friend going to college about 11 years ago. Gas tires and oil was all it ever needed. The girl gave it to her parents about 5 years ago and they are still driving it and it's still perfect! I guess the quality from Japan in the 90's went away in 2000. Too bad.
Old 12-02-11, 11:49 AM
  #105
ultm8mind
ultm8mind's Avatar
Mine is stuck in full high, wtf!! ALL sides front and rear, anyone have this issue? Pm me with the solution if you can assist, thanks
Quick Reply: LS430 UL with Air Suspension...Post your Issues Here
