Starting Problems After New Fuel Pump
Old Aug 31, 2004 | 08:10 AM
stanatl's Avatar
stanatl
Default Starting Problems After New Fuel Pump
I recently had the fuel pump replaced as part of the recall (also had the transmission replaced). Ever since I got my car back, I've seen a difference in the starting. It seems to crank for awhile before starting and sometimes requires trying it twice. This was never the case before the fuel pump was replaced.
Anyone here have a similar problem after the fuel pump recall?
Thanks.
Old Sep 14, 2004 | 07:53 PM
ethanhunt's Avatar
ethanhunt
Yeah,
I also have a more difficult time starting my car after a new fuel pump. Before it turned over with no cranking sound. I'm not sure what is causing it. I also has my timing belt changed at the same time.
Old Sep 15, 2004 | 04:57 AM
pvo's Avatar
pvo
It could be that the fuel pump wasn't installed correctly. I also brought my car in for recalls and ended up with 2 problems:
1. When they removed the back seat, they didn't put it back correctly. The car seat belt buckle of the middle is stuck beneath the seat.
2. A couple weeks later, my car died on the highway . I had it towed to the dealer. They found that the fuel pump and fuel float were not installed correctly.
Old Sep 15, 2004 | 05:02 AM
stanatl's Avatar
stanatl
Thanks for the responses. I have an appointment for a 15,000 mile service next week and have told them to check the starting problems. Interestingly it doesn't happen every time. Sometimes it turns over right away and sometimes it cranks for awhile then turns over.
I'll post a follow-up after the service is done.
Old Oct 5, 2004 | 12:07 PM
stanatl's Avatar
stanatl
Just had my 15,000mile service and told them about the starting problems. They replaced the fuel pump for a second time and told me they've been having some problems with the replacement pumps. It appears that additives in some fuels affect some percentage of the replacement units.
SCgonecray
Aug 20, 2012 09:20 AM
AlexAgyago
Apr 25, 2012 01:39 PM
epicaudio
Sep 1, 2010 07:18 PM
braheem
Mar 5, 2004 09:01 PM
