Valet trunk lock stuck?
Old Jan 22, 2026 | 02:42 PM
SoilTheCadaver's Avatar
SoilTheCadaver
Default Valet trunk lock stuck?
I was having trouble with my internal trunk switch and come to find out it was just completely disconnected. But now I can’t unlock it from the valet mode. My key won’t work on it but works on everything else.
i assume I have a valet key and when I bought the car the key had no buttons not an immobilizer.
the key works on everything else including the outside lock on the trunk but not the internal switch. I swear I unlocked it before and idk how to fix it. Any ideas?
Old Jan 22, 2026 | 02:55 PM
alextv's Avatar
alextv
Valet key would not open the glove box or the trunk.
Old Jan 22, 2026 | 11:46 PM
SoilTheCadaver
correct but I can open the trunk and glove box with my key so I don’t understand why I can’t unlock it with my current key
Old Jan 23, 2026 | 05:10 AM
alextv's Avatar
alextv
Should be able to but it may be a cut key and slightly off. Try wiggling.
Old Jan 23, 2026 | 08:10 AM
JffGRY706's Avatar
JffGRY706
agree wiggle it, but if that doesnt work disconnect internal switch, maybe reason disconnected
Old Jan 26, 2026 | 05:59 AM
BigBoomer's Avatar
BigBoomer
Probably got replaced so the barrel in that piece doesn't match your key, or it has simply seized.
As Jff ^^^ says there is a reason it was disconnected.
Old Jan 26, 2026 | 06:26 AM
CELSI0R's Avatar
CELSI0R
I would agree with others - It looks like the internal switches were replaced. You can see some chipping on the upper left corner of the release switch panel, and some marks on your dash around the edge of it from what I assume was prying with a tool or screwdriver.
ls400newbs
Jun 4, 2021 12:04 PM
Chione
14
Apr 20, 2020 04:46 PM
Frank400
Dec 29, 2014 08:25 AM
xxmariolxx
Apr 23, 2014 04:15 PM
pcroland
GS - 1st Gen (1993-1997)
Dec 31, 2003 01:46 AM
