UV blocking Headlight coating
Old Aug 25, 2025 | 12:22 PM
BigBoomer's Avatar
BigBoomer
Default UV blocking Headlight coating
Hi all,
I'm after some advice on what coating to use after sanding and polishing my headlights.
I have done it twice before and both coatings were pretty useless and lasted at best 2 years.
So, please share if you have a coating that lasts longer than that and is easy to recoat when needed.
Thanks 😄
Old Aug 25, 2025 | 02:18 PM
LatinLS430's Avatar
LatinLS430
Paint clear coat is probably the best
I'm planning on following this video soon. The Cerakote kit I have used is fading away after about a year.
Old Aug 26, 2025 | 02:26 AM
BigBoomer's Avatar
BigBoomer
But does that 2K Clear coat block the UV from getting to the plastic or does it just prevent oxidation by blocking air from getting to the plastic?
Old Aug 26, 2025 | 03:50 AM
CELSI0R's Avatar
CELSI0R
2K clearcoat adds a protective layer over the exposed plastic, so that the UV light attacks the clearcoat first
It's the same way how clearcoat protects the paint on your car. When the clearcoat is gone, the UV light fades and drteriorates your exposed paint. The clearcoat provides a protective layer that when waxed can further shield the surfaces beneath from wear
Old Aug 26, 2025 | 07:25 AM
BigBoomer's Avatar
BigBoomer
So, will I then need to be sanding back the clearcoat in 2 years time prior to repolishing, or does the clearcoat last longer?
I see lots of "how-to" videos but nobody saying "I did this 5-10 years ago and it has lasted well".
Ozzzzy
Dec 5, 2023 09:35 AM
Majorghn
Apr 22, 2023 12:19 PM
AndyT1
RX - 3rd Gen (2010-2015)
Dec 22, 2022 02:22 PM
user 710812323
Automotive Care & Detailing
Nov 19, 2020 04:29 PM
chaiyang7
Mar 24, 2012 11:34 AM
