Po125
Old Apr 14, 2025 | 10:42 PM
bigboat430's Avatar
bigboat430
9th Gear
Default Po125
can someone help me figure out how to fix p0125 i’ve looked up a few things but all of those things have been replaced
Old Apr 15, 2025 | 06:07 AM
weldthedif's Avatar
weldthedif
The P0125 code indicates an "Insufficient Coolant Temperature for Closed Loop Fuel Control". It means the engine control module (ECM) isn't detecting the engine's coolant temperature is high enough for the engine to run in closed-loop mode. This typically suggests a problem with the Engine Coolant Temperature (ECT) sensor or related wiring.
Old Apr 15, 2025 | 08:27 AM
tammap's Avatar
tammap
On some models, Lexus does not adhere to the SAE standard definition for DTC P0125 which is related to the ECT. Google does not work in this case for P0125.
You can see the diagnostic chart for complete diagnostic information regarding this codeHERE.
Best of luck!
Old Aug 25, 2025 | 04:46 PM
LEXUSturbo24's Avatar
LEXUSturbo24
I will be going with these once my run flats are done. This is for nx350 with 18s
https://www.discounttire.com/buy-tir...der-2/p/108567
viper.boy
Jul 25, 2008 09:00 AM
