Reverse lights not working 2001 LS430
My reverse lights will not come on. All the other lights work. I’ve replaced the bulbs and checked the fuses. I did a voltage test and it appears there is power to the bulbs. I’m not sure how it is possible to detect power and it is still not working. Any ideas?
If there is power to the bulbs but they are not lit up, then the lights have an earthing problem. Check that there is continuity between the outer of the bulb connector and a known good earth point.
thank you for your response. Yes, I did that today and nothing has changed. From my limited experience, if this is the case, it sounds like I would need to bring it into a shop to get it fixed.
