Driver door functions don't work
Hi!
I have recently bought an 04 Ls430, but today all the functions on the driver-side door have stopped working (except the driver-side window button). I can't lock it, and the soft-close and memory seat buttons don't work. Moreover, the mirror doesn't fold either on that side. Any idea what could be the issue? Thanks! |
Sounds like a blown fuse or a bad earth somewhere on that side.
Did you check all the fuses? |
Originally Posted by BigBoomer
(Post 11734593)
Did you check all the fuses? No, I have not checked the fuses yet, do you happen to know where would that fuse be located? Thanks a lot! |
I don't, but chances are it'll be in the drivers footwell since that is the fusebox closest to that area.
The inside of the cover has a graphic showing what each fuse is for. |
Thank you very much I will check!
| All times are GMT -7. The time now is 10:12 PM. |
