Transmission plug gaskets
Old Jul 17, 2023 | 10:23 AM
MaxKechely's Avatar
MaxKechely
Registered User
Default Transmission plug gaskets
Does anyone have the part number for the overfill plug gasket on a 2001 ls430 transmission, I have one for the drain plug crush washer and the part number is 35178-30010.
Old Jul 17, 2023 | 12:34 PM
Romanova's Avatar
Romanova
Looks like the fill plug gasket is 9030106196, is that what you're after?
Old Jul 17, 2023 | 01:52 PM
bradland's Avatar
bradland
I'm confused...
I didn't think the 2001 A650E's had on overfill port..?
Only the A761E uses the overflow plug/tube hence the absence of a dipstick.
Old Jul 17, 2023 | 02:31 PM
MaxKechely's Avatar
MaxKechely
Registered User
Originally Posted by bradland
I'm confused...
I don't know which model mine is but it has the dipstick.
Old Jul 17, 2023 | 04:19 PM
bradland's Avatar
bradland
I only have first hand knowledge of my 2006 but AFAIK there is no overfill port on the earlier 430's.
Maybe someone else can chime in to confirm..?
Old Jul 17, 2023 | 06:35 PM
MaxKechely's Avatar
MaxKechely
Registered User
It looks like from this picture of a 2001 transmission that it does have a fill plug around the middle, I will go ahead and check on my car later though.
Old Jul 17, 2023 | 09:08 PM
bradland's Avatar
bradland
The dipstick tube is the fill port.
Old Jul 17, 2023 | 11:22 PM
MaxKechely's Avatar
MaxKechely
Registered User
I meant to say the overfill plug, I guess I don't need to open it though if I have the dipstick I can just keep checking the level as I fill.
Old Jul 17, 2023 | 11:26 PM
MaxKechely's Avatar
MaxKechely
Registered User
Now that I'm looking at this picture I'm noticing the dipstick is connected to the pan, how do I take off the pan with the dipstick? I wanna replace the pan gasket because its leaking and the filter as well.
Old Jul 18, 2023 | 10:02 AM
bradland's Avatar
bradland
There is no overfill plug visible in the pic you posted.
Aisin overflow plug/tube is integrated into the pan.
The dipstick tube consists of 2 parts upper and lower. Once you detach the union the lower section comes out with the pan from below.
Pebblebeac
Jul 19, 2021 07:36 AM
Pebblebeac
Jul 4, 2021 02:50 PM
jdanielca
Sep 29, 2019 05:53 PM
ramram55
Jun 11, 2018 09:41 AM
Hgspine
RX - 1st Gen (1999-2003)
May 14, 2018 05:36 PM
