LS 400 Stinks
My air conditioning/heating system has a nasty smell like mold or mildew. I am guessing it needs to be disinfected. Has anyone experienced this and what can I do about it.
LG:
LOTS of threads on this subject if you'll try the search feature :). Here are a couple https://www.clublexus.com/forums/sho...threadid=81943 https://www.clublexus.com/forums/sho...threadid=98957 |
The problem is mildew on the outside of the coil under the dash.......Open the hood find where the condensation from the ac drips out maybe two drain holes , put a small tube in it long enough so you can pour in some diluted disinfectant ( pinesol or lysol ) You will need a funnel on the hose to pour in about a pint of your mixture the remove the funnel and blow it all in hold the hose up to keep mixture in system for about 5min.then remove hose and start car and run ac with windows down until most of the disinfectant is gone........The disinfectant smell will last a few days( if you car his two condensation drains under hood on firewall put another hose in that to plug it........................This is the only way to remove the mildew from outside coil without taking everything apart..............I have done this on different cars and it really works..........PM me if you have any questons.............MIKE
Thanks for the help. I'll try this method and report back my results.
Re: LS 400 Stinks
Originally posted by lexusguy My air conditioning/heating system has a nasty smell like mold or mildew. I am guessing it needs to be disinfected. Has anyone experienced this and what can I do about it. |
