Cooling system
Old Jan 13, 2022 | 02:44 PM
Brad400's Avatar
Brad400
So checked the hose where the arrow was pointing it’s warm but not hot to touch. That’s also how the upper radiator hose and the hose coming out of the thermostat feel as well
Old Jan 13, 2022 | 03:51 PM
bradland's Avatar
bradland
Originally Posted by Brad400
97 ls400. Burping is a *****. Lol. But when I drained the block not much came out at all. Where would I have a clog at? Blows cold air. It’s topped off at filler hole and resivour. Any help appreciated.
We prob should have asked more detailed questions from the beginning.
Why were you burping in the first place?
Did you recently replace any cooling system components?
What's the history (service life) of radiator, thermostat, water pump, etc...?
Old Feb 20, 2022 | 05:53 PM
Brad400's Avatar
Brad400
Well so my dumbass thought I had a bad head gasket when it was the power steering valve. But umm I put in head gasket sealer and huge mistake. Any help for this ding dong?
Old Feb 20, 2022 | 06:14 PM
Gerf's Avatar
Gerf
Try this if you want, on the pic with the red arrow there is a gear clamp with an 8mm head or you can use a flat screwdriver to loosen it.
Do this when the engine is fairly cool, grab the hose with the clamp loose and twist it so it turns freely then pull it partially off to see if there is any fluid coming from the hose.
If no or little fluid comes out remove the hose from the valve and put it somewhere that is a little higher than the heater control and put antifreeze in the rad until it comes out the hose...it will come out from the hose you removed first not the heater valve. That should get you heat fairly quickly after you relace the hose and tighten it.
That stop leak usually doesn't work anyway unless you pit in a quart or so.
Old Feb 20, 2022 | 06:27 PM
YODAONE's Avatar
YODAONE
Your water pump is in good condition?
If your thermostat is original, replace it.
Your radiator may be gummed up with head gasket sealer.
Check your ECT sensor probe for goop...if original, then replace it anyway.
Your heater core may be gummed up with head gasket sealer.......however, that is a more invasive project.
Start by swapping out your original radiator, thermostat and ECT sensor ..
Old Feb 22, 2022 | 09:34 AM
timmy0tool's Avatar
timmy0tool
agreed with all recommendations here as well, post gasket-sealer error!
i've said this many times before, i've never seen a head gasket failure on these engines! there was one that was close but it was not confirmed. i'm sure it's possible if intentionally done of course.
Old Mar 11, 2022 | 02:12 PM
Brad400's Avatar
Brad400
thermostat is newer not gummed up. Just put two new temp sensors on and a new radiator in. Still no luck. It’s gummed up somewhere I guess
musicman67
Oct 4, 2018 03:17 PM
billydpowe
17
Dec 27, 2017 11:10 AM
pacerdonfl
May 13, 2017 07:12 AM
rb240sx
Dec 12, 2013 10:34 AM
denverdog
15
Jan 19, 2011 06:41 PM
