99' Display doesn't work-what's the problem
It doesn't work at all.
I don't even know where the fuse is. 99 ucf20 jdm celsior. The display is messed up. https://cimg7.ibsrv.net/gimg/www.clu...18285107d9.jpg |
Do you know where the fuse box is? Open and look inside the lid, usually there is a fuse map there.
its japanesee..
Well I guess you could look up in posts or a member can post a picture of their fuse map (or from manual) for a 98-00 ls400. Assume it would be similar
The quickest way is to check all fuses using the method in the FAQ page but I'd rather think it is caused by a failed display unit judging from my past experience. I think I can fix it analyzing inside but it would be quicker to replace the unit finding a used working one since the unit is widely available these days.
I took a look at my notes and found this line I saved ages ago:
AC failed and blew the Bussman 15A fuse on the driver-side kick panel. I continued my journey to Orlando FL without AC and a blank-out LCD screen.
Originally Posted by Yamae
(Post 11088369)
koreaucf20, were those working before the display died? (also, thanks! I have Nav in my car and it's good to know there are OEM units available that work in the 2ndhand market) |
| All times are GMT -7. The time now is 01:11 AM. |
