Only Reverse works
Old Dec 7, 2020 | 05:25 PM
TheJapManR's Avatar
TheJapManR
10th Gear
Default Only Reverse works
So recently did a transmission fluid & filter change and topped it off with the Toyota Type-IV ATF, was having issues with drive and it worked for a second after I took it out for a light test drive around the block, but it felt as if it were slipping, it would drive but if I adding any gas it would slip, eventually got to a point to were reverse is the only working gear, curious to see if this is a solenoid problem, also threw a P0500 code so I (think) I can rule out the ECU/ECM being faulty. But I’ve also hear could be a shift linkage problem ask well.
Old Dec 9, 2020 | 12:24 PM
spuds's Avatar
spuds
Might get more responses if you post to this forum here.
MRonan83
GS F (2016-present)
Jul 25, 2025 10:43 PM
cristianhr
41
Oct 20, 2022 09:40 PM
Seashade
Nov 29, 2020 07:09 PM
getzac
Feb 13, 2018 02:50 AM
jehmin
Jun 6, 2017 02:47 PM
