99 LS400 strange power failure?
runs/drives like a dream. everything was fine yesterday and today, however it appears to have had some kind of power failure overnight. lost all memory presets. radio, navi settings and was in pacific region (default when power is out between battery changes etc., seats, clock, trip ODO mpgs and elapsed time all back to zero.
car fired right up. no warning lights, false codes or anything else. battery is only a few months old and terminals are surgically clean. clock was at 4:00 and i was in the car at 7:30, so it probably happened around 3am. just a weird fluke or could there be something up? |
If I read your post right, that is scary... you might retell your experience with a little more detail (mileage and such)
Originally Posted by billydpowe
(Post 10475021)
just lost all its memory. indicates a power failure to me. everything is fine with the car. everything feels great. just lost all its memory. what would cause that? |
I worry about that there may be some extra impedance at connections or the starter is about failing. I'd monitor the voltage drop of related lines when starting up using an oscilloscope which has a memory function.
Originally Posted by Yamae
(Post 10475055)
Connector issues causing body ecu problems
You have power, just not to all systems?
Body ECU..or you may have water on connector buss area in lower right passenger kick panel due to water spilloverfrom plugged sunroof drains....this was my issue. |
