Need help sourcing discontinued part 1993 ls400
Hello,
I am in search of a camshaft position sensor for a 1993 ls400 the part number is 90919-05010 (cali spec) and I cannot seem to find it if anyone can help me that would be highly appreciated thank you!
are you so socal or norcal?
I find many 1st gen LS400 at the local junkyard in Stanton and Ontario, socal.
you can pull a used one off an engine.
brand new, try: https://www.lexuspartsnow.com/oem-le...on_sensor.html
or the good ol 'bay': https://www.ebay.com/itm/Denso-Camsh...7x0d:rk:1:pf:0
Can you provide several high quality images?
Also made mention of the Mass Airflow Meter (cost of aluminum venturi.)
Super Moderator
This thread has some parts suppliers that may be worth a check:
https://www.clublexus.com/forums/ls-...ml#post8215417
Added this one yesterday:
https://parts.righttoyota.com/
(Is the Cali emissions aspect that critical???)
https://www.rockauto.com/en/catalog/...on+sensor,7192
Am I missing something here? Rockauto has 5 to choose from, granted not OEM but if availability is an issue...
Did you have any luck? I'm in the same boat. 1994 LS400 CA emissions. Could use some help. Thanks.
