Alternator problem need help
Old Dec 7, 2018 | 11:58 PM
YoungNas's Avatar
YoungNas
Default Alternator problem need help
Hi everyone, so I have been trying to fix this problem for almost a month now. When I tried to start the car, I used the multimeter to check for voltge, the battery gave me 12.2V while engine off, with engine on 11.4V. I knew then that the alternator is bad. I got new alternator still not charging. Then I replaced the 120a ALT fuse and everything started working and the alternator is charging the battery with 14.5V , I let the car for a while just to charge up the battery, turned off and went to sleep feeling happy that I fixed the problem. The next day I went to start the car and battery light turned on. Cheked the battery volts around 11.5-11.7v. What should I do next I’m confused.
Old Dec 8, 2018 | 02:35 AM
spuds's Avatar
spuds
Get a full charge on the battery with a charger.Then see what you have.
Old Dec 8, 2018 | 02:37 AM
Yamae's Avatar
Yamae
It would be better to inform us why you needed to replace the 120A ALT fuse. Did you use a jump cable?
Old Dec 8, 2018 | 02:56 AM
YoungNas's Avatar
YoungNas
Well I change the fuse because when I opened the fuse box I didn’t find the fuse, what I found instead the 2 metal legs of the fuse and there was solder between them. I think the previous owner thought that was a good cheap Idea?
and No I didn’t use a jump cable.
Old Dec 8, 2018 | 02:58 AM
YoungNas's Avatar
YoungNas
I don’t have a charger, I will just take it to a place charged and see
Old Dec 8, 2018 | 05:13 AM
Yamae's Avatar
Yamae
So the previous owner had blown the fuse. I worry that was deeply related to your current problem. I'd ask that owner the detail of what was happened.
My speculation is that the person used a jump cable but the polarity was reversed. This often causes a few to several other problems in addition to the open 120A ALT fuse.
Old Dec 8, 2018 | 10:20 AM
YoungNas's Avatar
YoungNas
I don’t know exactly becuase I bought this car a year ago and it was running perfect until now. The problem is I don’t have any contact with previous owner.
Old Dec 8, 2018 | 11:54 AM
RA40's Avatar
RA40
Super Moderator
Any user installed electronics? New stereo, lights...there may be a drain that has to be tracked down.
Old Dec 8, 2018 | 11:57 AM
Fit1too's Avatar
Fit1too
How old is the battery? Did this situation just develop? Definitely have the battery checked.
Old Dec 8, 2018 | 12:19 PM
YoungNas's Avatar
YoungNas
Yeah the battery is couple months old, and I’m charging it now in autozone. And the problem happened in one day.
Old Dec 8, 2018 | 02:43 PM
YoungNas's Avatar
YoungNas
Okay so I charged the battery and test it everything looks good, also unplugged the alt120a fuse and repluged it. Now the car started working and the battery is charging around 14.15-14.21V. Hope this time it will stay like this. If anything happened I will tell you guys tomorrow.
Old Dec 8, 2018 | 04:28 PM
Yamae's Avatar
Yamae
How did you hold the 120A ALT fuse when you re-plugged it? Did you use correct screws?
Incorrect screws may cause the Galvanic corrosion problem.
Old Dec 8, 2018 | 04:37 PM
YoungNas's Avatar
YoungNas
I used the same screws that were in the old fuse, but the fuse that I bought is this one https://m.autozone.com/electrical-an...750_19973?aqs=
Old Dec 8, 2018 | 05:30 PM
Htony's Avatar
Htony
How old is the battery? If you tune in AM radio, is there a lots of whiny noise? Your battery may have
one dead cell internally. Charging system problem can be confusing. If you don't exactly know what
tie cause is battery and alternator will start killing each other.
Old Dec 8, 2018 | 07:32 PM
spuds's Avatar
spuds
Sounds good.
If it goes dead after sitting a few days again do the parasitic draw test.Our cars are NOT good at charging fully dead batteries (claimed),and at least mine isnt.
Edit,I see post#8 posted same thing in video.
Lots of variations,but if 50 ma or less at battery you are good.Many other ways to test each fuse on you tube
