Need Ideas for my car
So I just bought a 1991 LS 400 & I just wanted some ideas on what types of things I can do to the car performance wise, this is my first car so I want to make it purrrty
I'm an "mod an upgrade" sort myself. There's lots of little details that can be done that aren't really expensive. The gated shifter mod is on my list, I just need to source an extra 90-94 gear selector and marry it to a 95-97.
There's also a ton of maintenance that you should check on first. The ECU is pretty major, and super cheap to fix, if you're handy with a soldering Iron. These are the sorts of cars that are great stock OR with serious mods and builds. It's really all in how you like your ride.
Welcome to the club!
Just keep up on the maintenance so it runs and drives good seeing how this is your "first car". The car should run better then it looks. Nothing worse then having a good looking car sitting in the driveway because it's broke down. I would wait a few months before putting major money into it just to make sure it's worth it.
Congrats on getting your first car.
DO NOT CLEAN THE ENGINE WITH A PRESSURE WASHER,BAD THINGS HAPPEN!!
go to lextreme.com if you're looking for performance upgrades and info
the LS is more of a just turn the key and enjoy the blissful serenity type car, if you want a toyota product with a lot of performance potential get a 2JZ powered vehicle
Check out YODAONE posts for a range of ideas.
From a maintenance perspective... ANYTHING made of rubber...
