LS400 crank without start
Old 10-26-17, 12:40 AM
Fai5al
Fai5al's Avatar
Default LS400 crank without start
Hi Every one ... New in here ..
I have this ls400 1997 that this morning stars give me hard time , I hardly reach home and I noticed this issue after filling steering wheel pump with oil that very light & smells like gasoline totally , I don't see any connection since I cancelled the 2 bonny ears lines that came from upper steering pump to the IAC valve , but this issue comes from nowhere suddenly after this.
video attached .. Thank you
Facebook Post
Old 10-26-17, 03:38 PM
dicer
dicer's Avatar
Check for spark and does the fuel pump run?
Old 10-28-17, 08:04 AM
Fai5al
Fai5al's Avatar
Sparks and fuel pump are OK the car start smoothly next day , but after few miles I noticed a smoke coming from under the hood , poor power and car went off with knocking sound , parked and checked , found cocked oil smell and boiling sounds coming from areas around intake . No overheating .. some said get your pocket ready for new engine
Old 10-28-17, 01:40 PM
RA40
Super Moderator
RA40's Avatar
Can you get any diagnostic codes with a code reader?
Old 10-28-17, 04:30 PM
Amskeptic
Amskeptic's Avatar
No overheating ..
"No overheating" .. ? I say you do have overheating. Maybe the coolant level is so low that the water temperature gauge does not register.
Check coolant at the bolt on top of the engine (when it is completely cold!) near the thermostat, not just the coolant bottle. Oh, and if someone says you need an engine without first thoroughly diagnosing it, forget them, they are just babbling nonsensically.
Colin
Old 10-29-17, 12:23 AM
Fai5al
Fai5al's Avatar
Positively sure no overheating, gauge stays cold from start and reach to 4 o'clock position after 5 minutes worming , reach to 3 o'clock position on driving and recently I just added second electrical fan with new clutch for engine main one.
What I'm thinking is what ever that cause of burning oil jumping from unseen areas around the engine , oil smoke get sucked by intake manifold causing bad reading to the car computer leading to poor power and making car go off . any corrections are welcome .
Note : intake manifold was removed to clean and found sticky oil in it and in all the lower intake manifold ports .
New thing this morning , heavy white smoke coming out from exhaust what about valve seals ?
smoke looks very same like this http://www.autoguide.com/auto-news/w...58-270x169.jpg
Old 10-29-17, 12:29 AM
Fai5al
Fai5al's Avatar
I might take it to repair shop later on to see, thought I might diagnose the reason first..
Old 10-30-17, 10:52 AM
Fai5al
Fai5al's Avatar
Colin
Broo I owe you an apology + RESPECT
Repair shop first new says I DO HAVE overheating , I don't know why gauge temperature NOT telling.. I'm shocked
In process of replace water pump as mechanic said and fixing rad.
Old 10-30-17, 03:49 PM
Amskeptic
Amskeptic's Avatar
Right here.
"Maybe the coolant level is so low that the water temperature gauge does not register."
Good luck!
Old 10-30-17, 11:14 PM
Fai5al
Fai5al's Avatar
What is the chances that the engine has not screwed up... any signs to make sure ?
HveezyF
09-24-18 10:32 AM
91LS400LEX
03-03-16 10:41 PM
gngai
01-12-16 06:53 PM
metsno1
38
02-01-15 08:48 PM
ZGagnon
32
05-23-14 08:12 PM
Quick Reply: LS400 crank without start
