Speedometer and Tachometer stopped working after wash
Old 06-11-17, 07:48 PM
jckol
Default Speedometer and Tachometer stopped working after wash
Washed my car and when I turned it on the Speedometer and Tach decided to stop working? Did I get a sensor wet or what could the issue be?
jckol is offline
Old 06-11-17, 10:45 PM
yoitskenn
yoitskenn's Avatar
Slap the dash board hard. It'll wake up
yoitskenn is offline
MK 300 (07-09-17)
Old 06-13-17, 12:36 AM
LS9698
LS9698's Avatar
Default Ditto
Yep, from time to time I have to give mine a smack right above the speedo. Not too hard though. Don't wear rings.
LS9698 is offline
Old 07-07-17, 08:43 PM
Fro98686
My tach just started to not work and happening more often. I also smack the dash above the speedo to fix. What is going on so I can fix correctly. Go behind the dash and push harness in direction it plugs in?
Fro98686 is offline
Old 07-11-17, 12:25 PM
Saurael
Angry Fro98686
Fro98686 Great question ! I too have been playing the congos on my dash when this happens. Other than the ecu caps issue, anything anyone knows to remedy this?
Saurael is offline
Old 07-12-17, 06:31 PM
djamps
I think you have to disassemble the cluster and lube up the spindle on the gauges, probably not a task for everybody given the complexity of these things. Mine usually works but ocassionally gets stuck at 0 and comes to life after about 40mph, I don't even realize it's dead until it jumps to life lol.
djamps is offline
Old 07-13-17, 04:29 AM
Rokas
Mine works but that main light doesn't so I can never see my speed but I feel it. I mean I've driven by those things that tell you your speed and I'm usually dead on without ever looking at the speedo, lol.
Also does the temp gauge get stuck like that too? Because mine is at the very bottom but I think I need to replace the temperature sender next to the coolant temp sensor.
Rokas is offline
Quick Reply: Speedometer and Tachometer stopped working after wash
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
