No dash light, warnings light up aswell as low gas
This picture is with my headlights on. Now - if there's a seperate button to illuminate the dash, let me know and slap me.
But I doubt that. However there is a huge amount of buttons, so I wouldn't be surprised (jk).
Anyway, the problem is self explanatory. One fuse WAS out. I forget the number but when I replaced it, the lights you see came on.
I just bought the car so I don't know if it was flickering before it went out. I did a search before making this post and I saw a lot of that but I don't know if that's my problem.
Someone mentioned fuse #13 and also #23, if I remember correctly. Should I check those?
Even though I can estimate my speed, it's nice to know how fast I'm going (the gauges work - I just can't see them).
I'm praying this is something easy! Thanks again guys. You might remember me. I bought that crashed '95 and it's running better than both of my parents' Ford Focuses (2002 and 2004) now. I fixed the mechanical stuff. I think secretly my dad envies me right now....
There should be a **** on the dash on the left side. (At least that's where it is on the 93-94) If you cant see the gauges only when you turn on the headlights then turn the ****, it must be all the way down.
also I couldn't help but notice your steering wheel is all the way UP?! the tilt and telescoping function can be repaired!
https://www.clublexus.com/forums/sc-...ng-repair.html
chaacmool1
SC- 1st Gen (1992-2000)
11-13-14 07:49 PM
