Rear Dome/Map/Reading Lights Not Working ('98 LS400)
Rear Dome/Map/Reading Lights Not Working ('98 LS400)(Solved)
Alrighty, time for me to ask a dumb question.
Just went to all LED for the interior lighting.
I thought the two furthest back lights in the rear didn't work because the bulbs were dead.
After installing the LEDs, I realized that they still don't work no matter what (front doors being open, rear doors being open, turning the front dome light to "on"/"door", nothing).
Every other light as far as I can see works just fine including the trunk and rear map lights.
There is no buttons anywhere in the car that i've noticed that controls these lights.
I would assume it would be on the same circuit of the rear map lights..but looks like i'm wrong. They also didn't work before the LED install. So I haven't been able to learn when they're supposed to actually turn on to begin with.
So questions -
: When are these lights supposed to turn on
: Are they on their own fuse, if not, what do they share a fuse with? (only asking because non of my fuses are bad)
: Does the front come light controls (door/off/on) control these lights
Before I get yelled at. I tried my hardest finding threads in regards to this already xD
Any advice?
Much appreciated!
Solution
So, after talking with a friend frome
our local club. Turns out you have to turn on the courtesy light while the car is on for that light to come on. Both are now working.
fordsvtmfl
01-07-11 05:38 AM
