(1998 LS400) How Do I Replace the Coolant Temp Sensor?
Old 02-18-16, 04:50 PM
Charlestob
Charlestob's Avatar
Smile (1998 LS400) How Do I Replace the Coolant Temp Sensor?
I have the new sensor, and I believe that I've located the old one, but I'm not sure how to go about replacing it. Do I need a torque wrench? Do I need to remove the part where the air intake connects to the throttle body? Do I need to reset the ECU?
Thanks So Much,
Charles
Old 02-18-16, 06:11 PM
timmy0tool
timmy0tool's Avatar
this is covered in the Frequently Asked Questions thread, but since you're new, here is the link to the info you need. please use the FAQ next time.
https://www.clublexus.com/forums/ls-...ange-pics.html
the process is similar to your 98. no you don't need a torque wrench, but do not overtighten. you may need to remove the intake tube to access your ECT. yes you should reset your ECU for best results.
Old 02-18-16, 06:18 PM
timmy0tool
timmy0tool's Avatar
i believe the ECT sensor is that one in the lower middle, green connector.
Old 02-19-16, 11:22 AM
mappo
mappo's Avatar
You need a deep well 19mm socket for the ECT sensor. A normal socket, and even some supposed "deep" sockets (I'm looking at you, Tekton) are too shallow to swallow the plastic part of the sensor and engage the metal hexagon part.
Here's a post of mine with a pic showing the sensor location on the 98-00:
https://www.clublexus.com/forums/ls-...ml#post8836371
Old 11-16-18, 05:04 PM
Juelz21
Juelz21's Avatar
I know this is old but which part number did you use? I notice theres 2 different ones and im not sure which to use for our generation (98+)
Old 11-16-18, 07:58 PM
RA40
Super Moderator
RA40's Avatar
Part# 89422-20010
Fits the following:
https://www.lexussouthatlantaparts.c...942220010.html
89422-30030
Fits the following:
https://www.lexussouthatlantaparts.c...942230030.html
Click the what this fits tab to see the reference
Old 11-16-18, 08:01 PM
Juelz21
Juelz21's Avatar
Originally Posted by RA40
Part# 89422-20010
Fits the following:
89422-30030
Fits the following:
Thanks for the help! Installing tomarrow
bk2thamax
SC- 1st Gen (1992-2000)
14
03-17-14 07:38 PM
sam12345
01-13-12 12:26 PM
lexus_sc40
Performance & Maintenance
06-30-09 12:03 PM
kwikrnu
12-29-07 05:32 AM
dnguyen_GS430
08-22-01 09:52 PM
Quick Reply: (1998 LS400) How Do I Replace the Coolant Temp Sensor?
