Lower steering wheel without power.
I have a 1990 LS400 that I need to get the instrument cluster out of but we have no key for it so the steering wheel will not move. Anyway to manually lower the steering wheel?
you could remove the lower plastic cover under the wheel,
open the gear box up and remove the gear. then turn it manually by hand - you may break the motor ------ which is valuable
check this thread for some pics of the gear assembly
https://www.clublexus.com/forums/sc-...ng-repair.html
yes its in the sc forum but it'll apply to your ls
