1998 - 2000 ls400 replacement wiring harness connectors
Images contain complete listing of O.E.M. Lexus - Toyota wire loom harness connector shells for 1998 - 2000 LS400. Some overlap for 1995 - 1997. Contact pin P.N.s are not shown, but are available through Lexus ans, or Toyota. Better solution than hacking a perfectly good wiring harness with and splicing a pigtail.
The following 4 users liked this post by YODAONE:
This should be pinned if it isnt.
This removal tool for 15 dollars has a great following online
LISLE 56500 Wire Terminal Tool
https://www.ebay.com/itm/LISLE-56500...Cclp%3A2334524
I copied/saved the pics for my Lexus files and then i could rotate and zoom in on them.They are good quality pics.That worked for me on my end.
https://www.clublexus.com/forums/ls-1st-and-2nd-gen-1990-2000/914937-1998-1999-2000-ls400-replacing-ignition-coil-connector-housings.html
You are better off with the set of Craftsman picks depicted in ignition coil connector post
https://www.clublexus.com/forums/ls-...-housings.html
It does not appear the multi-tool depicted earlier is useful in extracting Sumitomo connector pins from their shells.
A long probe-like tool depicted here aids extraction of terminals from Sumitomo connector shells....more refined than Craftsman
Googled sumitomo removal tool 12094429 and this is what came up..
Attached terminal.Repair brochure references this tool under Sumitomo section
toyotasrfu
09-03-07 07:23 AM
