diagram of the plug/plug wires to the rotor
I just changed the plug ,wires,rotor and cap.Everything is almost put back together, but in case it doesnt start , I need to find out where each plug wire goes etc...I just didn't understand the #s on the CAP.Please................. in layman's terms.Starting from passenger side plug and then wires and then to ignitor in that fashion.
Thx
Thx
Jerk after tune up but not all the time
Yes I figured out that diagram and quite easy.Everything is back together and it cranked right up .I had a jerk that came intermitently within about 10 miles of driving.It seems to came with a medium to hard acceleration..I also got a PO125.I had changed the fuel filter 3 days ago(ordered from ebay) and I am not sure if the ebay filter is causing the jerk or the code.I cleared the code and I will see in the next coming days.I have also kept all the plugs,wires,capos and rotors in case something goes wrong
This sounds like a spark plug wire is not seated on one of the plugs right. It may be a good idea to double check the routing of the wires. Make sure that you don't have arcing between the wires.
