Replaced clockspring in '96 LS, now airbag warning light is on?
Old 06-20-15, 08:40 AM
3803's Avatar
Default Replaced clockspring in '96 LS, now airbag warning light is on?
Hi, was very pleased to have back my horn and cruise control after replacing the clockspring in my 1996 RHD LS400 (UK model).
The replacement clockspring came out of a 1996 JDM Toyota Celsior.
However now the airbag warning light is always on. Its just a minor annoyance but would be nice to eliminate it.
Would appreciate some help with the following:
1. Could the UK model airbag be incompatible with the JDM Celsior clockspring (but the other functions all work perfectly)?
2 Would resetting the ECU reset the light ie. take off the battery terminals for 30 minutes or so?
3. Otherwise, how do I reset the warning light?
Many thanks in advance
Old 06-22-15, 03:28 PM
RA40
Super Moderator
RA40's Avatar
I would suggest disconnecting the neg battery cable to reset the ECU. If the airbag light comes back on, recheck the connectors under the dash and those near the steering column.
Old 07-04-15, 09:00 AM
3803's Avatar
Sorted. Turns out the replacement clockspring was the problem plus my old clockspring was fine.
There were 2 wires on the right side of the steering that had been cut somehow. I replaced them and used the old clockspring and horn and cruise worked fine.
Old 07-05-15, 10:44 AM
RA40
Super Moderator
RA40's Avatar
Thanks for posting back. What was wrong with the replacement clock spring? Wrong size...etc.
Old 07-06-15, 12:56 AM
3803's Avatar
Looks exactly the same but kept making the airbag light turn on. I guess its either incompatible with a UK-market LS400 or damaged somehow (it came from a salvaged Japan-market Celsior).
shlounek
SC- 1st Gen (1992-2000)
03-09-23 03:30 PM
MySc4fever
Performance & Maintenance
10-05-10 06:08 PM
SoufSidah
01-20-06 01:00 PM
supercoupes
11-01-01 05:49 AM
Quick Reply: Replaced clockspring in '96 LS, now airbag warning light is on?
