2000 Lexus LS400 Turn off Automatic Steering Wheel Tilt
Old 02-26-08, 02:07 PM
lenunn1923
lenunn1923's Avatar
Default 2000 Lexus LS400 Turn off Automatic Steering Wheel Tilt
I have a 2000 Lexus LS400
Does anyone know how to turn off the automatic steering wheel tilt and
still allow you to manual tilt the steering.
Thanks
Larry
Old 02-26-08, 02:46 PM
Neofate
Neofate's Avatar
I believe you can look to the side of the steering column and their are options for what you are requesting. Otherwise I am not sure. This feature apparently bothers you?
Old 02-26-08, 03:57 PM
lenunn1923
lenunn1923's Avatar
Default Yes it bothers me
My 93 had a switch, but there is no switch on the 2000 model.
I have heard it can be turned off.
Thanks anyway
Old 02-26-08, 06:41 PM
Kansas
Kansas's Avatar
The automatic tilt/telescope feature is a customizable setting. A handheld tester with the appropriate program card is required.
File Type: pdf
Old 02-26-08, 07:33 PM
Neofate
Neofate's Avatar
Sure -- I didn't know you knew about the First gen's.. and I don't see why they would remove the switch on later models. It now requires a special tester with a card. That is removing convenience imo.
What about this feature makes you want to turn it off? I'm curious.
Old 02-26-08, 07:43 PM
sonyman
sonyman's Avatar
You can't turn it off at all on 1995-1997 models without physically disconnecting power to the tilt/telescopic motor.
Old 02-26-08, 08:02 PM
McSwine
McSwine's Avatar
I've got a 2000 and if I could easily turn it off, I would. I don't have any problem getting in and out and I just don't need it. Plus, I'd rather get in and go instead of waiting for it to do its thing.
Old 02-26-08, 08:04 PM
dashan
dashan's Avatar
Is there a how-to for 95-97?
Thanks
Old 02-26-08, 09:20 PM
Kansas
Kansas's Avatar
The on/off switch was probably removed because almost nobody turned the auto tilt/telescope off. I owned a 90 LS400 for 13 1/2 years and never once turned the auto tilt/telescope off with the switch.
A common reason to turn the auto tilt/telescope feature off is if there is a failure in the tilt/telescope mechanism. A fairly common problem with the tilt/telescope feature of the 98 to early 2000 LS400 can cost up to $2,000 to fix. I previously posted the TSIBs about these issues on this forum.
Old 02-26-08, 09:21 PM
skperformance
skperformance's Avatar
If you want an easy way to turn it off pop the cover off around the key cylinder. The their is a single wire leaving a tab on the side. Pull it off and the key will no longer activate it on a 98-00. The only other wire goes to a ring around the outside of the cylinder for the immobilizer and the other is a bulb to light around it.
Old 02-26-08, 09:30 PM
KevinfrmSD
KevinfrmSD's Avatar
You guys are worried about turning it on and i'm more worried about fixing it so that it works properly. Haha. Btw, mine is a 96.
Old 02-26-08, 09:31 PM
Neofate
Neofate's Avatar
Good tip there skperformance.
I happen to like the vertical action of the steering wheel on entering exiting the vehicle, and I never have a problem getting in or out due to it 'doing its thing'.
I can get in with it down completely or out the same way. In fact I commonly cannot or do not get out before it has gone up.
It takes , in my vehicle, a second maybe 1500ms to go from bottom to top.. I'd have to pretend my car was on fire to really have it get in my way
Has yours slowed down ?
To each his own, If mine didn't have the 'off' feature I would probably try and figure out how to turn it off just because of that fact ..
Mine is 14yrs old and it moves at the same speed as it did new. ( Or same speed as an 05 LS.) -- Only thing I can compare it to.
Old 02-26-08, 09:32 PM
Neofate
Neofate's Avatar
Interesting. Is this a very common problem for a '94 LS 400? If it does go out, then I will turn mine off and manually adjust when I want.. as I do not want it to wear out.. and having it 'auto' move isn't necessary for me. (I am not overweight).. Only about 5'11, 205lb.
Certain year models have more problems than others?
Old 02-26-08, 09:36 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
theres a tilt fix on the UCF2x faq
Old 02-26-08, 10:12 PM
lenunn1923
lenunn1923's Avatar
Default Can i still manually adjust the Steering Wheel up and down and in and out ??
Thank you, for the information
But, if i disconnect the wire, Can i still manually adjust the Steering Wheel up and down and in and out ??
Larry
Quick Reply: 2000 Lexus LS400 Turn off Automatic Steering Wheel Tilt
