Power Hick up?
Old 03-10-14, 01:54 PM
BigBalloo
BigBalloo's Avatar
Default Power Hick up?
Hay gutlys im have my 92 ls400 for about 2 months. So the issue ive been having is the the car hick-ups on take off with light throttle. I am thinking that this might be the throttle boddy getting stuck but not sure . Any help will do thanx.
Old 03-10-14, 01:58 PM
RA40
Super Moderator
RA40's Avatar
This may also have some additional info for you:
https://www.clublexus.com/forums/ls4...capacitor.html
Old 03-10-14, 03:27 PM
timmy0tool
timmy0tool's Avatar
i second the ECU capacitors, but you can also check the transmission fluid. when was it last changed? it should be a nice red color. use only toyota type T-IV automatic transmission fluid when filling.
Old 03-10-14, 03:36 PM
LScowboyLS
LScowboyLS's Avatar
also, please use the procedure here to dump the diagnostic codes, the ECU will have a record of any misfires and point to the suspect component
post the codes here once you have them and we will analyze them for ya!
temptingin
06-05-19 06:02 AM
Peli
08-01-17 01:19 AM
sparrowjac
07-09-15 10:23 AM
vindell
02-19-15 12:11 PM
chris07is
Performance
07-20-14 11:17 AM
Quick Reply: Power Hick up?
