93 LS400 Tensioner Idler Pulley fit a 96 ?
Old 01-26-14, 07:52 AM
MattLS400
MattLS400's Avatar
Default 93 LS400 Tensioner Idler Pulley fit a 96 ?
Members,
Could a 93 LS400 Engine Motor Belt Tensioner Idler Pulley fit a 96 LS400 ?
Old 01-26-14, 09:04 AM
steve2006
steve2006's Avatar
Should be the same although different part numbers, whats the problem with the old one as you can replace just the bearing for a few $$$s.
Old 01-26-14, 11:08 AM
MattLS400
MattLS400's Avatar
Thanks steve....This is my problem
Old 01-26-14, 05:27 PM
YoshiMan
YoshiMan's Avatar
Looks like the threads are toast.
Old 01-26-14, 06:21 PM
MattLS400
MattLS400's Avatar
Yup..Would changing the entire pulley with bracket solve the problem ?
Old 01-26-14, 07:19 PM
YoshiMan
YoshiMan's Avatar
Yes, the tensioner can be unbolted and tossed out, and a new one put in it's place. I wouldn't even mess around with the old one. the previous owner probably just torqued the bejesus out of it!
If it answers your question, on Rockauto the aftermarket tensioners are designed to fit a variety of years, some of them fit 1990-79 models, others fit 1990-2000.
However, if the Toyota part numbers are different for the two years like steve2006 said, you may want to get more specfic and just stick with OEM
Old 01-28-14, 04:20 AM
MattLS400
MattLS400's Avatar
Thanks Yoshi....I decided to put the extra couple bucks and I got a 96 Pulley
Attached Thumbnails 93 LS400 Tensioner Idler Pulley fit a 96 ?-kgrhqv-p0f-ifyi-dbq-c442fvq-60_3.jpg
dashan
21
03-10-18 02:25 PM
flpgbc
10-13-15 12:50 PM
MadMaxxNA
01-18-08 03:11 PM
hermenu
12-26-06 08:22 AM
Quick Reply: 93 LS400 Tensioner Idler Pulley fit a 96 ?
