Door Ajar Switches
Old 01-05-14, 09:24 AM
Michael
Michael's Avatar
Default Door Ajar Switches
All of my door ajar switches are sticking. It works sometime and not in other. When a door is open, if I play with the switch little bit, the interior light comes on.
Has anyone did something about this switches. Is this something I can take it apart and oil it little bit to make the fix or must I replace all four switches?
If I have to replace them, how much are they each?
Thanks in advance for your reply.
Old 01-05-14, 10:30 AM
dc893
dc893's Avatar
http://www.lexls.com/tutorials/elect...fcourtesy.html
It doesn't look too difficult to replace them and they look like they cost about $20 from Sewell Lexus. Replace them and you should be good for about another 20 years.
I haven't had this problem yet in mine but I would probably just replace them.
Old 01-05-14, 01:53 PM
Michael
Michael's Avatar
Default Courtesy Switch Replacement
dc893,
Thanks for the great lead to the solution. I visited the lexls.com often and missed that one.
It doesn't look that bad but the procedure looks like it is involved than I though it would be.
That takes care of front switches but any lead on the rear door switches? Looking at the front procedure, it looks like you have to get to the switch from the trunk it seems......
I am also wondering if the part number for all four would be same? Just checking to make sure...
Old 01-05-14, 02:08 PM
dc893
dc893's Avatar
http://lexus.sewellparts.com/oem-cat...S400-1993.html
The top two are the front and rear switches.
https://www.clublexus.com/forums/ls4...placement.html
I couldn't find much in regards to the rear door switch. It's not that much work to get the front ones out.
Old 01-05-14, 02:49 PM
Gene01
Gene01's Avatar
Replacement will surely last longer than lubricating the switches, but if you do, don't use oil.
It will collect dust over time and make the problem worse.
Try a graphite lube (alcohol-based) on the switch plunger surface.
Old 01-05-14, 04:09 PM
YoshiMan
YoshiMan's Avatar
Silicone spray works well too. Used it on my Landcruiser switches and they worked like new, plus it isn't oil based and won't attract dirt and filthyness.
Old 01-06-14, 06:43 AM
LScowboyLS
LScowboyLS's Avatar
dry graphite powder is a great lube for applications such as this!
Old 01-06-14, 07:39 AM
Michael
Michael's Avatar
Default Rear Switch
Has anyone attempted to took the rear switch out to lube?
GCNTSi
RX - 1st Gen (1999-2003)
13
02-24-19 09:30 PM
garyr
12-02-16 06:58 PM
jbdvm1988
GX - 1st Gen (2004-2009)
02-13-12 08:05 PM
turbo1
11-21-07 07:14 AM
lexus4ever
Maintenance
03-11-03 12:28 PM
Quick Reply: Door Ajar Switches
