Transmission cooling hoses
Old 12-20-13, 07:25 AM
GKLCPA
GKLCPA's Avatar
Default Transmission cooling hoses
I'm looking to replace the two hoses that go into the bottom of the radiator as a pre-emptive measure. One them was weeping. I believe these are the trans cooling hoses. What are the part numbers for these? Can I just pick up some hoses at my local autozone? I'm assuming that these aren't high pressure hoses.
Old 12-20-13, 02:46 PM
LScowboyLS
LScowboyLS's Avatar
you can use good quality fuel line - do not use coolant hose - and you had better do this job the long, slow, meticulous way, if one of those hoses comes loose, you have likely burned up the transmission! - also, I would use the real Toyota clamps
Old 12-20-13, 03:01 PM
GKLCPA
GKLCPA's Avatar
Noted, particularly on the clamps. It was a non toyota clamp that was loose that was causing some slight leaking. Thanks LS!
Elless400
16
06-12-17 06:47 PM
LexBrett
10-09-14 12:28 PM
rbigshow04
SC- 1st Gen (1992-2000)
08-03-11 04:20 PM
lexluger71
Performance
06-03-08 05:11 AM
CDALTON
Performance & Maintenance
01-06-04 07:17 PM
Quick Reply: Transmission cooling hoses
