Need help.. Hessitation under hard acceleration
Old 12-18-13, 04:23 PM
ExpoGeorgi
ExpoGeorgi's Avatar
Default Need help.. Hessitation under hard acceleration
How's it going ClubLexus! I haven't been here in a while but I have a problem with my 1994 LS400.
It started recently I was on the highway doing 70mph, tried to accelerate past a truck and when I press the throttle (for hard acceleration) it bucks and the motor wont rev over 3000 rpms. Now if I ease on the gas it has no problem slowly getting up to speed. Car idles normally and sounds healthy.
Has anyone had this issue? What should I look for?
Old 12-18-13, 05:37 PM
Gene01
Gene01's Avatar
I'm sure that someone more knowledgeable than I will post, but it sounds like it may be a Throttle Position Sensor, among other things.
Old 12-18-13, 05:45 PM
Yamae
Yamae's Avatar
Sounds like a fuel supply problem to me. A clogged fuel filter often causes your type of problem. I would be checking the fuel line first. Have you changed the fuel filer in the past? The fuel pump or fuel injectors might cause the problem too.
Old 12-18-13, 08:00 PM
ExpoGeorgi
ExpoGeorgi's Avatar
Thanks for the reply guys, ill look over some of it tomorrow and hopefully get her to a shop next week when I go home. Any other suggestions are welcome.
Quick thing whenever it begins to hessitate the engine light comes on then goes off. Haven't been able yo find a place witha obd1 code reader yet
Old 12-18-13, 09:13 PM
Yamae
Yamae's Avatar
You should have informed this at your first post.
The clogged fuel line or weak fuel pump does not turn on the engine check light. You must have a more serious issue. You need to get the code first to solve the problem. Without a code reader, you can simply diagnose the problem putting a jumper wire at the DIAG connector. Search the forum and you will find the detail.
Old 12-18-13, 09:51 PM
LScowboyLS
LScowboyLS's Avatar
you can easily download the codes with a small piece of wire, using the method shown here.
Doublebase
03-26-22 12:26 PM
pdembow
04-05-12 12:24 PM
hotlex
GS - 1st Gen (1993-1997)
03-13-05 04:43 PM
Vik
08-11-03 09:03 PM
kathleenkmh
Performance & Maintenance
05-23-02 05:31 AM
Quick Reply: Need help.. Hessitation under hard acceleration
