Looking To Reduce The Guillotine Effect On The Trunk
The trunk on my '95 LS 400 closes very violently. When fully opened, just a little push of the trunk and it will slam shut. Obviously this is because the trunk is very heavy, but my concern is that I may inadvertently chop off fingers or decapitate babies' heads if I am not careful. First question: do all the LS400s' trunks close this way. Second: is there any way to make the trunk close more carefully?
Have you guys tried replacing the trunk struts? I have replaced them with ebay parts with very good results... I think you're struts are shot and don't allow the trunk to close correctly as it did when it was new.
er... I can't remember... maybe the 95 does not have the struts.... oops.
yes, something is amiss, my trunk will not slam shut ever, yet, if I want to close it, I can do it with a single finger, perfectly balanced and everything is stock!
Thanks, guys. Remember that I inherited this car from my late father, so I am not the original owner. I will do a quick eBay search of "trunk shocks" or "trunk supports" to get started. I am indeed very concerned because sometimes when I change shoes at the golf course I support myself with my hand inside the trunk as I put on my golf shoes. I fear that a little carelessness or even some wind can cause amputation, which would be detrimental to my golf game.
OK, guys, I just bought the trunk supports for $78 and I look forward to replacing them. Has anyone replaced them and are they easy to replace? If not, I can just take them to a mechanic and pay him to do it.
Should be pretty straight forward. And the new struts should come with instructions. One thing you might have to do, is swap out the support ball mounts on both the lid and the trunk frame. Usually it won't fit on the existing ones. Should just pop off a clip and slip the strut off the ball mount. Then possibly replace the ball mounts and press the new one in place and pop on the new clip.
If they are similar to other model years.
Update
I just picked my car up from the shop and the new trunk supports work perfectly. However, the trunk supports I bought from eBay did not come with "clips." This is what the invoice read:
Note: trunk supports did not come with new clips.
Re-used old clip is on one side
other one is broken
OK, so the trunk appears to work perfectly well on one clip, but what will happen if the existing old clip breaks, too? Will the trunk slam like a guillotine again?
What should I enter on my next eBay search to find these new clips?
other one is broken
