Code 13 help
Old Oct 22, 2013 | 02:27 AM
etj1085's Avatar
etj1085
Default Code 13 help
Does anybody in his forum have any clue how to REALLY fix a code 13. I have been through every test posted on this site and nothing will fix my issue. I'm not interested in anyone's speculation. I need the check engine light to go off. I'm so done with spending hour after hour with this piece of only to have the light come back on yet again. My next procedure will be to drain the oil and put a brick on the pedal and laugh with delight as it explodes. Sick of this LS !
Last edited by RA40; Oct 22, 2013 at 03:33 AM. Reason: descriptive title & profanity
Old Oct 22, 2013 | 03:45 AM
RA40's Avatar
RA40
Super Moderator
Didn't state which year you have but generically:
Did you recently do a timing belt change?
Check that the cams and belt is in the proper position.
Cam sensor is ok?
All vacuum lines are ok and not split or detached.
Also keep in mind this:
https://www.clublexus.com/forums/ls4...capacitor.html
Old Oct 22, 2013 | 07:04 AM
LANcr3w's Avatar
LANcr3w
It could be:
ECU
Crankshaft position sensor
Open or short in circuit
Skipped timing
goodluck
Old Oct 22, 2013 | 01:19 PM
LScowboyLS's Avatar
LScowboyLS
Originally Posted by LANcr3w
It could be:
ECU
Skipped timing
goodluck
all of those plus cam sensor
I would say the best odds are jumped timing belt, pinched cam sensor wire on passenger side, ECU, and passenger side cam sensor, in that order
usually if it is crank sensor you will also get code 12
LiCelsior
32
Nov 4, 2025 11:31 PM
Deathbarel
Mar 20, 2017 10:24 AM
frotiss
Jul 28, 2014 08:30 AM
whtricsc40
IS - 1st Gen (2001-2005)
20
Oct 10, 2012 08:26 PM
NSeagle78
Jul 7, 2011 04:49 PM
