sc430 wheels fit on ls...
Old 05-03-13, 06:53 AM
Bluegs300
Bluegs300's Avatar
Default sc430 wheels fit on ls...
any help.. anyone running this setup at all??? well the work???
Old 05-03-13, 07:04 AM
xtremex626
xtremex626's Avatar
you obviously didn't use the search future. been many ls400s throughout the whole generation that has been on sc430 wheels.
Old 05-03-13, 01:48 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
agreed, need to search more.
they fit on all year LS400s, but '95-00 will need a 15mm spacer to clear the front brakes.
Old 05-03-13, 10:13 PM
Sc0pe
Sc0pe's Avatar
1990-1994 (UCF10)
1995-1997 (UCF20 Zenki)
1998-2000 (UCF20 Kouki)
Quite a few members seem to run these as a beginner setup. As far as I'm aware, the wheels themselves are 18x8 with a +45 offset all around. Also, as everyone else stated before, the search feature would have come in handy as there's a bunch of threads along the lines of what you're looking for.
Old 05-05-13, 03:05 PM
Bluegs300
Bluegs300's Avatar
Thank u.. I'll try and do my best to search...
Old 05-05-13, 05:16 PM
Lavrishevo
Lavrishevo's Avatar
I like mine.
https://www.clublexus.com/forums/ls4...ld-thread.html
Old 05-06-13, 11:17 AM
adamls2
adamls2's Avatar
Looks so damn awesome!
Old 05-08-13, 03:31 AM
munday
munday's Avatar
Completely stock suspension, 15mm eibach spacers on the front and nothing on the rear.
A word of caution, I had to cut down my front studs to allow the wheels to sit flush with the spacer
Old 06-21-19, 08:12 AM
MrWallace
MrWallace's Avatar
Is anyone running these on a 3rd Gen LS? Mine is an 04' and I think it would look sick, but will they fit though?
Old 06-21-19, 08:15 AM
Sin1UZFE
Sin1UZFE's Avatar
wow the color and the rims along with stock suspension....very sexy indeed
Old 06-22-19, 08:36 AM
Losiracer2
Losiracer2's Avatar
yep 15mm front and 25mm rear hubcentric spacers (60.1mm hub, 5x114.3 bolt pattern) should do the trick. That setup was completely flush on my 97 LS with 235/45/18 tires and nothing rubbed at all, even over large bumps like railroad tracks or doing lock-to-lock U-turns.
Old 12-03-19, 08:54 PM
Bryan561
Bryan561's Avatar
Default Stock suspension or lowered ?
Stock suspension or are you lowered on coilovers or anything ?
Old 12-04-19, 02:42 PM
Losiracer2
Losiracer2's Avatar
stock shocks, everything factory height.
Old 12-04-19, 05:00 PM
Sin1UZFE
Sin1UZFE's Avatar
Source on some cheap ones?
RXGS
02-27-17 08:59 PM
Brandicus
Wheels and Tires Classifieds
24
02-18-08 08:27 AM
TeamAM
05-04-07 04:41 AM
rclab1
04-10-06 07:46 PM
400DGRZ
10-29-05 09:33 PM
Quick Reply: sc430 wheels fit on ls...
