Noise from rear passenger suspension
Old 02-13-13, 03:31 PM
midwest2
midwest2's Avatar
Default Noise from rear passenger suspension
Hi all,
After replacing most of the front suspension on my 96 LS400 the rear is starting to act up. The passenger rear suspension makes a very sharp almost metallic sound over larger bumps. The best way to describe it would be the sound of a very tight bolt which kinda screeches the first turn or so when you bust it loose. I can't duplicate the sound by bouncing the car and I didn't see anything obvious when I took off the wheel. I have replaced the rear carrier bushings and the rear springs/shocks in the past. The first thing I will replace is the sway bar endlinks because they are cheap. Any other suggestions would be appreciated! The car has 156k on it.
Old 02-13-13, 05:33 PM
YoshiMan
YoshiMan's Avatar
probably just a dry bushing in need of some white grease
Old 04-12-13, 02:57 PM
midwest2
midwest2's Avatar
I wish someone had some better guesses at this. I'm not real hip on greasing every bushing and the sound is not going away. It's about as knarly a sound as u can imagine. Can the rear-upper ball joint be frozen and causing a noise? I hate to just throw parts at it.....
t2d2
Suspension and Brakes
23
04-05-15 02:12 PM
wvuguy
RX - 1st Gen (1999-2003)
13
12-29-09 10:23 AM
ECUgs430
08-23-07 08:55 PM
balticbsc3
01-29-06 08:12 PM
ridah
07-10-03 11:21 PM
Quick Reply: Noise from rear passenger suspension
