Hello, I got a misfire from my car
the code are
P0300 Random Misfired
P0303 cylinder 3 misfired
P0305 cylinder 5 misfired
I changed the spark plugs and the spark plugs wire but it seem still misfire. I did a search but it seem every thread the thread starter seem to disappear and not post how they solve their problems -____-.....
if it keeps indicating cylinders 3 & 5 then it will fairly easy to figure out, either related to fuel or ignition or engine issue in those cylinders
most likely suspects:
distributor caps
injectors
the problem will definitely be one of the following:
Ignition System
Injector
Fuel Line Pressure
EGR
Compression
Valve clearance
Valve timing
MAF meter
Engine Coolant Temp. Sensor (ECTS)
ECU Capacitors
why not start with replacing dist. caps & rotors, ECTS, and ECU capacitors, in that order, as these are three common problem areas in a 96 LS and use genuine Toyota parts for ECTS and distributor caps & rotors
when it idle it sputter like alot, engine shakes alot too
it sputter less when i step on gas. should i post a video of it? kinda hard to explain
crap i forgot to get the result but cylinder 1 has no compression and cylinder 3 has a low compression
if you did the compression test correctly, and you truly have no compression in cylinder 1, then you have major engine issues, i.e. a bent valve or a hole in the piston etc. - there is no low cost fix for these kind of problems, you are looking at big money, as no small problem can cause complete loss of compression in a cylinder.
how confident are you in your compression testing tools and ability?
bent valve? thats what scares me... but if there was a bent valve wouldnt all the other valve would be bent as well with it? maybe i should just stop driving the car far huh?
Originally Posted by hotdawwg
Autozone bro.... I even think Pepboys can do a free test!
actually none of them do free test i went earlier =[
Originally Posted by PureDrifter
did you recently have any work done on the car? when was the last time the timing belt was changed and what's your current mileage?
