Go Back  ClubLexus - Lexus Forum Discussion > Lexus Model Forums > LS Models > LS - 1st and 2nd Gen (1990-2000)
All my crazy Lexus issues SOLVED!! (ECU-leaking capacitor) >
Old 01-16-19, 06:48 PM
  #1546
Yamae
Liked 164 Times in 128 Posts
Originally Posted by Assim View Post
so the ECU is the problem? Can i fix it?
The suspect is the MAF or the connection to it.
Yamae is online now
Old 01-16-19, 06:56 PM
  #1547
Assim
Liked 0 Times in 0 Posts
I forget to mention the cruise control not working too.
Assim is offline
Old 01-16-19, 07:50 PM
  #1548
Yamae
A 95 has a separate computer for the CC.
Yamae is online now
Old 01-17-19, 05:22 AM
  #1549
deivis163
You'd better to read this first.
https://www.digikey.com/en/articles/...-loop-response
I have written several times before about the capacitor's selection. You need to study a lot about the Bode plot and measure the actual circuit, if you want to use non recommended capacitors. Too low ESR capacitor often causes problems of stability or RF oscillation, you know. Without analysing the relationships between the phase and the gain of the error amplifier, the person would have very hard time to compensate.
Of course it would be nice if you were planning to use non recommended ones and inform us the result with the chart.
Yamae, do you have any chart with ESR values, which is the best for capacitors? I'm asking this because I found few of charts with different values, I would to like measure capacity and ESR before replacing capacitors.
deivis163 is offline
Old 01-18-19, 08:11 PM
  #1550
Yamae
Sounds like you still need to study the Bode plot some more. Those who understand it would never ask such a strange question.
Yamae is online now
Old 01-19-19, 01:50 AM
  #1551
deivis163
Ok.. I can change capacitors without measure them.. I just want to make sure, that new capacitors is better condition than old.. I think sometimes you can get bad/defective new capacitor and make everything worse after replacing them. I just want to make this task 99% good.
Old 02-11-19, 12:08 PM
  #1552
LS400SC400
Can anyone recommend a company I could send my California 1992 LS400 non traction control ecu to, that would do the best job?
LS400SC400 is offline
Old 02-11-19, 01:07 PM
  #1553
TaninAuto
Sponsor
TaninAuto's Avatar
Liked 24 Times in 21 Posts
What issues are you having?
__________________
TANIN AUTO ELECTRONIX
262-456-4147
[email protected]
www.taninautoelectronix.com
Follow Us!
Facebook || Instagram || Youtube
TaninAuto is offline
Old 02-11-19, 01:34 PM
  #1554
LS400SC400
Surging on accelleration, some popping noises, and worse when not totally warmed up. Previously have replaced spark plugs, plug wires, caps, rotors, fuel pump, fuel filter, coil packs, fuel strainer, cleaned throttle body, replaced mass air flow sensor, and have run separately through three tanks of gas, techron, sea foam, then Lucas fuel system treatment.
Old 02-11-19, 01:36 PM
  #1555
NPHendo42
Liked 3 Times in 3 Posts
Default 2jzgte ecu capacitor location and value?
Is there a plot chart for the capacitor locations and their respected values? i.e. C104, C106, ect for a 2jzgte ecu? i cant find pics or posts anywhere
NPHendo42 is offline
Old 02-20-19, 02:35 PM
  #1556
gymguy79
Liked 1 Time in 1 Post
Wrist straps are flexible conductive bracelets with a snap on conductive wire that is used to discharge any static electricity that you may on your body that would arc to the electronic ICs that are on a board you may be working on. Many work stations that are used in prototyping circuit boards (CBs) or even reworking CBs have a metallic or conductive work surface that the wrist strap is connected to. The wrist strap wire is connected to this conductive surface. When the circuit board is placed on the surface it is assumed to be at the same potential so touching components on the board will not result in a discharge and possible failure to ICs. Long explanation.
A picture would be better.
gymguy79 is offline
Old 02-20-19, 08:45 PM
  #1557
gymguy79
Another technique that I haven't seen used by anybody so far is solder wick. One of the most destructive procedures for removing radial caps in platted through holes (especially in multilayer boards) is trying to extract the caps without damaging the plated hole. The hole is connected to internal layers where the plating is thin. If most of the solder is not removed or kept liquid the hole can be destroyed by being pulled out as the cap is removed.
Solder wick is braided copper strips that have been impregnated with a flux that is activated by heat. The strips come in various widths from 1/16 to 1/4 inch and is rolled up onto a plastic spool. By placing a piece of the strip on the back of the board where the tip of the cap comes through the board and heating it with the soldering iron the solder will literally be wicked away much like water is taken up by a sponge. In most cases there is very little if any solder left on the lead or the hole and the cap leads can be teased away from the hole with the iron.
Any solder left on either side of the board can be cleaned up with the wick as well. I've had good luck with solder wick with surface mounted components as well.
gymguy79 is offline
Old 03-10-19, 09:06 PM
  #1558
wsaharem
Default 1995 sc300
My 1995 SC300 has 89661-24370.(maybe CA version?) Unfortunately I cannot see 1 of the CAPs, so after reading numerous pages of this thread, realized that I'm close to -24350, so with the total cost of $14 including shipping, just buying 2 of each..
89661-24370
1 - 10uF - 50V (1 add from 24350) mine is 24370)
1 - 47uF - 63V
1 - 100uF - 10V
1- 220uF - 16V
2 - 15uf - 35V
and one unknown.. I'm pretty sure it's one of the above, so buying 2 of each. In all the threads, I've never seen 3 of one kind.
The reason I cannot see 1 of the CAP's is because one side of my circuit board the philips screws are soldered over. This "looks" like it was factory, but has anyone seen this?
All 6 screws are soldered over, so will be difficult to remove them. Impossible to put the same ones back in.
wsaharem is offline
Old 03-10-19, 09:27 PM
  #1559
gymguy79
I may be wrong since I only have rebuilt 93 and 94 LS400 ECUs but there are screws on the other side that hold another board. You take off these screws and fold back a flex cable that attaches both boards to expose the caps.These are not soldered if your ECU is like mine.
gymguy79 is offline
Old 03-11-19, 02:57 PM
  #1560
wsaharem
Yep, have taken that one side off, but the one side that is soldered in place has a tiny capacitor in a corner covered by an aluminum part of the case that is impossible to read, AND will be tough to replace. But I've since seen others that have those same soldered on screws, so I think this is normal. I'll just have to find a way to twist my hands or tools into ungodly shapes to get this done
wsaharem is offline
Quick Reply: All my crazy Lexus issues SOLVED!! (ECU-leaking capacitor)
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
