All my crazy Lexus issues SOLVED!! (ECU-leaking capacitor)
#1532
Here you are: https://www.taninautoelectronix.com/...00-ecu-repair/
__________________
TANIN AUTO ELECTRONIX
262-456-4147
contact@taninauto.com
262-456-4147
#1534
I don't know if you were trying to get a hold of me about the repair i just got on my 2006 GS430, if so my email is 23.98psf@att.net
#1535
Hi, guys i’m Assim from Middle East glad to be with you and I really want some help with my ls400 95
I changed all 6 caps in the ecu after that the obd2 works again shown the code P0100 and P0110 I checked the voltage in the maf sensor 11.35v then I checked the MAF sensor was at idle 3.83 g/s and the voltage between terminal VG and ground 1.183v finally the resistance between EVG and ground 198 ohm. Any suggestions??
#1536
Hello,
I would like to share information about ECU 89661-50252, I found here 9 capacitors, I though I will find in my ECU 6 capacitors, because of the model year 1995, but I need to order more capacitors and replace them. I'm just decided to do the maintenance for my ECU, but all capacitors now looks fine.. Anybody know any information about this ECU? Does it has some fixed issues?
List of capacitors which I found:
10v 100μF x2
35v 15μF x2
50v 10μF x2
63v 47μF x2
16v 220μF x1
10v 100μF x2
35v 15μF x2
50v 10μF x2
63v 47μF x2
16v 220μF x1
#1537
I need some more information to suggest you further. Since you already know pin assignments and I ask you these below without explaining them.
1, What is the resistance value of the temperature sensor which can be measured between THA-E2. Does it behave as is shown in the chart below? You need to check the resistance at least 2 points of cool and hot like 2.5kohms @ 20 degrees C and 0.35kohms @ 60 degrees C.
2, How much is the read-out voltage of EVG-E1 at idle?
#1538
Hello,
10v 100μF x2
35v 15μF x2
50v 10μF x2
63v 47μF x2
16v 220μF x1
10v 100μF x2
35v 15μF x2
50v 10μF x2
63v 47μF x2
16v 220μF x1
Electrolytic capacitors can't be checked by human eyes, you know. The quickest way without removing capcitor to check is to use an ESR meter. The simplest way would be to measure the ripple level as is shown in the FAQ. I suggest you to replace all those 9 capacitors. You will be amazed at the better performance of the engine.
#1539
See the old posts #172-177 of the thread. The ECU is designed to meet regulations of each countries and the number of capacitors varies depending on the market. European models are not the same with USDM and your ECU is not OBD-II compatible.
#1540
Hi, I have a question, when I try to buy capacitors on the main menu they list different types of material, if someone can please guide me on the material needed thank thank you for this valuable info Yamae and Lscowboy you guys are life savers 🙏
below is the list of capacitors on digikey.com
Accessories
Aluminum - Polymer Capacitors
Aluminum Electrolytic Capacitor
Capacitor Networks, Arrays
Ceramic Capacitors
Electric Double Layer Capacitors (EDLC), Supercapacitors
Film Capacitors
Mica and PTFE Capacitors
Niobium Oxide Capacitors
Silicon Capacitors
Tantalum - Polymer Capacitors
Tantalum Capacitors
Thin Film Capacitors
Trimmers, Variable Capacitors
Capacitors
Ceramic Capacitors
Film Capacitors
Silicon Capacitors
Tantalum Capacitors
#1541
The voltage VG-E1 1.183V @ idle is too low. It should be min 2.0V.
voltage 2.8mV EVG-E1
#1542
#1543
#1544
https://www.digikey.com/en/articles/...-loop-response
I have written several times before about the capacitor's selection. You need to study a lot about the Bode plot and measure the actual circuit, if you want to use non recommended capacitors. Too low ESR capacitor often causes problems of stability or RF oscillation, you know. Without analysing the relationships between the phase and the gain of the error amplifier, the person would have very hard time to compensate.
Of course it would be nice if you were planning to use non recommended ones and inform us the result with the chart.
#1545
