Lexus Stealership
Did you know that Lexus recommends changing the transmission fluid at 100k miles. I know this sounds crazy but this is the factory recommended interval. It seems to me, that you run a greater risk by introducing too much new fluid at once. This may cause sludge to Loosen in large and damage the transmission. The recommended procedure is to introduce only 2 courts at a time that way it will not dislodge any sludge in large amounts. I don't believe that dropping the pan will hurt anything but I think that you are wasting your money. Given, that it is only a screen in there and not a filter. Don't forget to buy a new drain bolt and washer if you remove them.
Jun 11, 2018 06:46 AM
OldLs400
Jan 17, 2018 10:01 AM
Lukas99GS
Oct 4, 2014 07:40 PM
Bradster
Mar 6, 2003 10:17 AM
